Os Install
Discussion in 'Operating Systems' started by fightingfi, Aug 8, 2019.
  1. fightingfi
    fightingfi Look at Me! I need the attention.
    2,576
    Oct 9, 2008
    When i do a clean build new pc new fresh install of windows do i update everything including all of windows and updates for it first before i install motherboard drivers 2nd?
  2. elavanis
    elavanis n00b
    42
    Feb 1, 2008
    I would update the motherboard drivers before windows updates if only because windows might try to install a newer driver than the base install but older then the one you are putting on.
  3. ir0nw0lf
    ir0nw0lf [H]ardness Supreme
    6,297
    Feb 7, 2003
    I have a USB flash drive with all the latest drivers for all the boards/video cards/etc I build with. I always let Windows Update go first then install the drivers from the flash drive -- the WU drivers are never newer for me. But I guess it really doesn't matter, personal preference I guess.
    dvsman and DeaconFrost like this.
  4. DeaconFrost
    DeaconFrost [H]ardForum Junkie
    11,026
    Sep 6, 2007
    I always keep a flash drive updated with necessary drivers, but I would at least make sure you have your network drivers downloaded and saved before hand. That being said, I also do the motherboard/chipset drivers first, then let Windows Update install whatever it finds. I always install my graphics driver from a download as well.
  5. AltTabbins
    AltTabbins [H]ard as it Gets
    18,979
    Jul 29, 2005
    Get all the drivers you will need first and put them on a usb drive. When you install windows, keep the network cable unplugged and WiFi disconnected. Install the drivers first thing offline. Then update. Windows has a bad knack of installing ancient drivers for sake of stability.
