Options for directional antennas?
Discussion in 'Networking & Security' started by ITGuy1024, Feb 23, 2016.
  1. ITGuy1024
    ITGuy1024 n00b
    53
    Jan 22, 2016
    I'm trying to shoot wireless a little ways down the road to my friends house. I've found a lot of omnidirectional antennas but not so much for directional. Other than using the old coffee / pringles can method does anyone have low cost recommendations?
    Hooking up to a WRT54g of course.
  2. Skripka
    Skripka [H]ardForum Junkie
    10,792
    Feb 5, 2012
    You need directional antennas on both ends. The router is less of a signal power problem than the wifi-adapter. You can't have a connection unless both can talk with each other.
  3. ITGuy1024
    ITGuy1024 n00b
    53
    Jan 22, 2016
    Thanks, I'm aware that I'll need two.
  4. FLECOM
    FLECOM Modder(ator) & [H]ardest Folder Evar Staff Member
    15,589
    Jun 27, 2001
    common directional antennas would be
    Yagi antenna
    Dish antenna
    Grid antenna
    Sector/Sectoral antenna
    for what you want to do dishes would probably be your best bet... check out the stuff ubiquiti has, a lot of them have the radio built into the antenna so you just run network cable/poe to it
