My stock Opteron 165 is 45C at idle and up to 61C under load. This is totally unacceptable. Temps have slowly been rising over time, but the weather here (and my lack of air conditioning) are likely causing that. I currently have the Scythe FCS-50 and it was doing the job (less than 55c under load) until recently. I want to get those temps down! What are you using on your Opteron 165?
My mobo is an Abit AN8 SLI board. The FCS-50 barely clears my RAM and is a really tight fit. I'd like something a little more comfortable.
Also, my case has a side intake fan, but the FCS-50 blocks that airflow because it blows air parallel to the processor surface and not perpendicular as with most HSFs.
