TerranUp16
- Dec 11, 2007
Both of my five year old CD/DVD drives that I carried over from my old PC (whose motherboard bit the dust last summer) to my new one have conked out, leaving me with only my newer Asus CD/DVD drive that I bought last summer. In modern times you'd think one drive would be enough but it gets to be rather annoying since I use my PC for everything- particularly when I'm at my dorm as my PC and its dual monitors serves as my primary gaming platform, DVD player, TV, etc... Net result is that there are a few DVD's that I typically always keep in-drive which I then usually like to leave one additional drive open then for hot-swapping in whatever I need.
Anyway, I want to replace the dead drives with a Blu-Ray drive (which will solve my HD movie issue- just have not yet found a good digital distro service for that yet) and don't much care about Blu-Ray burning- primarily interested in it for playing movies. So I've been looking around at drives and have been trying to find something palettable and affordable for that and [ur=http://www.newegg.com/Product/Product.aspx?Item=N82E16827106292]this[/url] seems like it's got quite a bit of potential. Since the NewEgg page isn't very forthcoming with specs, I looked them up myself. 8x Blu-Ray ROM read speed, 16x DVD, and 48x CD. The only blemish I can find on the drive is the 2MB buffer which seems a bit small compared to others I've seen but most of those seem to be burners and/or lack the rather good read speeds of this one.
Was wondering if anyone has any comments on this specific drive from usage or better familiarity with optical drive specs and/or if anyone has any other suggestions I should consider.
