HardOCP News
[H] News
- Dec 31, 1969
I figured since you guys liked Brian's other video on data caps, you'd also get a kick out of this.
Are sentences like these the result of inking?He's saying specifically that don't make any sense.
He's saying specifically that don't make any sense. He's working on a document which I assume is on the desktop and the weather app keeps popping up and he has no idea why?
Are comments like this the result of trolling?
The question requires 'yes' or 'no' as valid responses.
Ditto for my question.
So this guy is trying to be like Ben Yahtzee Croshaw? Even used the same style/art that he uses on Zero Punctuation.
And finally . . . nearly 30 minutes into your review, er . . . rant, you admit that you only used it for 30 minutes.
So your recipe for reviewing goes like this:
Use for 30 minutes.
2 hours writing
1 hour recording audio
2.5 hours animating
Conclusion: you spent more time complaining about Windows 8 than you did using it.
Disable start screen.
Install StartIsBack.
Done. Once the familiar desktop is back, the improvements under the hood make windows 8 much more worth it. It takes literally about 15 seconds to get the old desktop back.
The migration to Linux begins.
I watched this video a couple of weeks ago - and while I agree with _some_ of his points, I question his ability to use _ANY_ computer by some of the comments he made and his total lack of troubleshooting skills.
In other words, he's a fraud trying to make a buck with a fancy video that isn't exactly accurate.
I'm responsible for new pc purchases for a number of organizations. The video re-affirms my concerns. This OS is not good for getting WORK done in a corporate environment. I couldn't imagine buying a bunch of pc's running this and then distributing to the users. It would be a complete nightmare of calls for support and questions.
They say never say never. But I will never purchase a pc running windows 8 for a corporate environment.
