Opinion on this build, and need advice on case asap!
NIZMOZ
Here is my build with the help of a few others here, but I made some changes. I already bought the video card as soon as I saw it go into stock. Also is the power supply enough for that card?
So, I am missing a case and can't figure out what case would make this setup look nice, good airflow, dust filters, and be some what quiet?
https://pcpartpicker.com/list/yBwhyX
NIZMOZ
Oh well, hope this is a good one. I ordered the setup I have listed above due to discounts ending shortly.
ReaperX22
Very expensive board for no real benefit... But solid build otherwise.
What case did you end up with? or not ordered yet? You've limited yourself to cases that only support 280mm rads.
Perhaps the Fractal Design Define R6? Tempered Glass?
