Emulsifide
- Jan 24, 2011
i changed some settings due to your suggestions:
napp-it 0.414o changelog:
- pw-length now max 16 char (does not work on Nexenta, without modifications, Nexenta use only first 8 char.)
- if you change/ set a user pw, you have to enter twice
- menu disks, identify drive via dd (does not work on all systems)
Awesome! I will give this a shot tonight when I get home. Thanks!
EDIT: Actually, I've got another one for ya. When rebooting, my encrypted folders lock back up which is great. However, if those folders are shared out via SMB, I must un-share them and then re-share them after decrypting the folder. Is there any way you can have the interface reshare the folder "if and only if" the folder was shared out prior to decryption?
If this doesn't make sense, let me know and I will provide pictures.
