CaseyBlackburn
- Dec 10, 2006
I am having some issues currently with my OpenVPN connection. The client is no longer able to access the remote network other than the server. On the remote network the server is the only one who can access the client. Please help.
Server Config
Client Connection
Server Routes
Client Routes
Server Config
Code:
; daemon configuration
daemon
mode server
tls-server
proto udp
port 1194
user openvpn
group openvpn
cd /var/openvpn
client-config-dir clients
; tunnel configuration
dev tap1
server-bridge 10.100.2.1 255.255.255.0 10.100.2.225 10.100.2.254
push "route-gateway 10.100.2.1"
client-to-client
passtos
comp-lzo
management 127.0.0.1 5555
keepalive 10 120
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
persist-local-ip
persist-remote-ip
; logging and status
writepid /var/run/openvpn.pid
ifconfig-pool-persist openvpn.leases
status /var/log/openvpn/openvpn-status.log
verb 1
; certificates and authentication
dh /var/efw/openvpn/dh1024.pem
ca /var/efw/openvpn/cacert.pem
cert /var/efw/openvpn/hostcert.pem
key /var/efw/openvpn/hostkey.pem
auth-user-pass-verify "/usr/bin/openvpn-auth" via-file
username-as-common-name
client-cert-not-required
client-connect "/usr/local/bin/dir.d-exec /etc/openvpn/client-connect.d/"
client-disconnect "/usr/local/bin/dir.d-exec /etc/openvpn/client-disconnect.d/"
Code:
/usr/local/sbin/openvpn --client --pull --comp-lzo --nobind --dev tap0 --ca /etc/cacert.pem --auth-user-pass /etc/openvpnusers --remote xxx.xxx.xxx.xxx --ping-restart 120
Code:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
x.x.x.x * 255.255.255.128 U 0 0 0 eth1
10.100.2.0 * 255.255.255.0 U 0 0 0 br0
default eth2.4 0.0.0.0 UG 0 0 0 eth0
Code:
10.100.2.0 * 255.255.255.0 U 0 0 0 tap0
x.x.x.x * 255.255.0.0 U 0 0 0 eth0
default 192.0.2.1 0.0.0.0 UG 0 0 0 eth0
