I can get that far
I mean if I come up with a ACL scheme from scratch (for a group projects share for example) I will probably do some Dumb Stuff or at least re-invent the wheel. I don't know how it is I can't find any google results that say "set your permissions like this". And it seems like I need to do some things in a certain order to get things propagated the right way.
Thanks as always for your help Gea!
Will a RAID 10 of four Hitach 5k3000 2 TB drives be faster than a single 10k Raptor?
Also, should I disable sync writes on my datastore pool ONLY or should I also disable it on my RAID-Z2 archive/media pool?
I set this up and with 2 x 10 drive zpool2 (raid6) arrays. I powered off the VM to replace 2 drives and then booted it up and napp-it isnt starting... how do i see which services are running and restart http?
I'm having trouble deleting files from SMB shares (from windows) that were downloaded on my solaris machine via SABnzbd (python usenet downloader). I have all the ACLs set to full-set for everyone for the SMB share.
note: the folder is owned by the sabnzbd user on the solaris machine, however the permissions on the folder are 777 and I can delete it via the command line (from my user) or using SFTP via WinSCP.
When I try to delete the folder I get this error: you require persmission from S-1-5-21-3711944786-4061020791-2851930098-1103.
Is there any way to fix this? Or is this just an incompatibility between unix permission's and ACLs.
Maybe the only way is to use pylibacl to set the ACL in the python code upon download.
You must either smb connect as root or smb connect as root and set desired ACL recursively
to change ACL of already created files. Folder permissions are only inherited if you set these
prior of creating files.
There is no incompatibility between ACL and unix permissions, they depend on each other.
If you change unix permissions, ACL changes accordingly - the same when you modify ACL
Most problems occur if unix programs not aware of ACL change permissions wth
the result of modified/ deleted ACL (ACL are much more universal than traditional unix permissions)
Solaris ACL are very similar to Windows ACL. Main difference is that Solaris respects order of ACL
while Windows processes first all deny rules then all allow. So try to avoid deny rules otherwise
you must set them from Solaris.
I've just finished setting up my "All-In-One" ESXi + ZFS box. Basically, I have ESXi with a virtualized ZFS server. I'm sharing an ESXi datastore using iSCSI through ZFS.
However, when I reboot ESXi, it takes about 10 minutes and stops at loading "iscsi_vmk".
After it finally boots, it doesn't automatically remount my iSCSI datastore, even after my ZFS server is booted.
What can I be doing wrong?
large and significant performance difference between iscsi and nfs. NFS + slog isn't entirely awful but iscsi is still going to be faster.Is there a performance difference between iSCSI and NFS?
Thanks for the response as always.
I could manually mount the iSCSI datastore every boot if there is a big (any?) difference in performance...
EDIT: Also, should I have one ZFS folder that ALL VMs are stored in, or should I create separate ZFS folders for each VM?
It's not just the hit rate, tf you have a lot of ghosts in your ARC you could benefit from SSD L2 to grow the ARC and minimize the repeat evictions.you should check your cache hit rate first to see if there is any vale, I suspect there will not be with 12GB ram unless you have a very heavy small random read usage. also check the read rate and iops as it may be worse than the raidz array if they are old ssd's.
as for use as an os partition, nope, no value here...unless you just want to see it boot faster...and you'll have way less space for snapshots of the rpool...so that's a big negative. you should leave the 250gb mirror as is IMHO.
it's likely they are of no value to the server.
As for ZIL, if you are doing the all-in-one it makes no sense to have sync enabled on performance intensive NFS folders imo.
Yea arc_summary.pl is how I did it too. Ben Rockwood (he wrote it) has a good YouTube series about zfs tips.True about the L2ARC, but only the person with that particular system can tell if it will help. I found a program arc_summary.pl that prints out all this useful info. Ghosts are never an issue on my all in one. Agree 100% on your point about sync=disable vs zil for the all in one.
You can make a folder deticated to datastores and disable sync on it and leave sync enabled on the other zfs folders shared to hosts outside the ESX server.Good point - I hadn't really considered the pointlessness of sync writes for VM's hosted on the same machine. (Assuming that the zfs host is only exposing shares to locally hosted vm's - if it has any "off-machine" shares then there might be some utility).
In case anybody is interested, I ran some benchmarks to compare NFS and iSCSI (hosted on ZFS)
Interesting. You might want to post this on the virtualization board and see if anyone there has a thought as to why iscsi reads are so much faster than nfs. Lopoetve there is an actual vmware guy and is quite knowledgeable.
Keep in mind that iSCSI VMs will not come up after a reboot (of the host). ESX will see the iSCSI HBA as not available until after you do a rescan. So, after a reboot you'd have to open the Windows based VMWare management console, rescan the HBAs, and then your VMs would re-appear. Not good if you want things to come up on their own, or if you don't have any Windows machines (aside from your VMs).
afp22p6 installs a beta of 2.2.0
newest netatalk (stable): 2.2.1
wget -O - www.napp-it.org/afp | perl
http://www.napp-it.org/downloads/changelog_en.html
Thank you, will I still need to add the line to the afpd.conf or is this automatic?
Thank you
