Hi, I need to move two disk from the onboard controller (amd motherboard) to my new 1068e controller. If I move them with the system off, in the next boot, the will be detected and mounted or the system needs to be resilvered?
thanks
but for mac os lion which i got last night was only able to access to the root folder of my smb share. can't go any further.... keep prompting no access to the folders in smb share
any idea?
- you have to add a user to Solaris not to winXP
- you must connect as root or a SMB user mapped to root to change ACL share-settings from Windows
(does not work with every Windows version like home or ultimate edition)
- or set permissions with napp-it ACL extension for local users (under development)
I just put in my 1½ years old 2TB hard drives that was running a raid60 before.
Right after i added them i have 9 out of 21 with errors. Should i disconnect them and check then in another PC or is there a way in napp-it to check them?
i expect a total disk failure rate of about 3-10% per year with new disks
After say 5 years that will grow significantly
errors on the other hand are quite normal. they are not a problem. if they
become a real problem, the disk will change its state to fail.
But if numbers of errors are increasing suddenly, its a sign of a future failure
of the disk or of another part of the system. In this case you can try the CLI tools
of smartmontools or the manufacturers tools to check a disk
I'm not sure i'm doing this right.
The problem is that when i connect to the share as root i can't add another user it can't find the user. Its tried with both a user from the domain and a user made in napp-it. When i make another user and try to use that it fails. I don't think the new user i made have the rights for the folder.
I use not that many disks, my experience is up to 20-50 disks of a type
but i have had up to 10% per year drive failures in the past ( desktop type disks or some special types)
with bad disk series and with some newer sandforrce ssd's
oh Steve what are you doing
Macs than can only connect i.something
In Lion
AFP to current Netatalk server: problem due to new authentication
SMB to Unix SMB server: problem due to change from Samba to new SMB implementation
http://forums.macresource.com/read.php?1,1186081,1191038
untested but published workarounds
AFP:
http://www.alexanderwilde.com/2011/04/os-x-lion-connection-error-with-afp-and-workaround/
SMB
Go to Finder, click on Go->Connect to Server or simply press command + K.
Connect to your server by typing smb://your.ip/hostname or use cifs://your.ip/hostname
Login, and you should be good to go.
Do not use the link in Finder under the Shared category
Having the same issue here under a workgroup scenario. I think there's a way to make the users appear through 'idmap' (Services -> SMB -> user mapping). I messed with it for awhile, but wasn't able to get it to work for me.
I was thinking I could create an SMB user from napp-it, and have that same user appear in the Windows ACL screen. Couldn't get it to do that. All I saw when doing a search were a bunch of groups. No users at all listed, not even root.
Maybe we are doing something wrong? I cant find any step by step or anything like it for doing this.
I had 8 out of my 32 WD RE4-GP 2TB go. most died after 1 year of running 24/7
This is an amazing poor failure rate! Did you run them in a sauna or or really hot case?
Neither AFP nor SMB work for me in Lion. AFP throws an error saying unsupported version. SMB will mount the share, but then tell me that I don't have permissions to access it. The same account (root) works fine in Snow Leopard.
I got Steve Jobbed![]()
In Lion
AFP:
SMB
There is a suggested AFP solution from Jason:
In order to compile DHX2 support in the UAMs of Netatalk 2.2.
You have to install the libgcrypt11-dev from apt-get. Once libgcrypt11-dev is installed,
Netatalk will compile with DHX2 support and in return will allow computers running Lion to login
about AFP and Lion
i have currently no Lion to check but if you are on NexentaCore
you may start testings with my netatalk 2.2 beta 4 installer with included libgcrypt-dev via
wget -O - www.napp-it.org/afp22 | perl
if someone wants to try installation on OI
see http://wiki.openindiana.org/oi/Netatalk
lib is on:
http://www.opencsw.org/packages/CSWlibgcrypt-dev/
WIll the napp-it installer work with OI?
wget -O - www.napp-it.org/afp | perl works with OI/ SE11 and Nexenta
(netatalk 2.15, has problems with Lion)
the afp22 installer (netatalk 2.2 beta4, needed for Lion) is currently Nexenta only
(tested howto for libgcrypt-dev on OI needed - and i need to buy and install Lion first)
about AFP and Lion
lib is on:
I suggest give up smb, go back to samba, if just use for home NAS
I've try smb for 1 week,
it's really not good for use.
and if I move files from smb directories to not smb directories under the same pool,
smb do copy and delete, not cut and paste, means long long time
and I have more than 200,000 photos,
if one pool have a smb directory,
when remove files to another pool (No smb exist)
it's very slow....
maybe 9MB/s..........
both pool have 6disks raidz2
Hi, First my apology I did not go through the entire thread to see how exactly you construct your filer. Notable thing though,
1. For extensive high density file server build, proper physical housing to reduce vibration and other impacts is very critical (meaning here overall environment to reduce potential impact to minimal)
2. I understand some will argue they buy proper server case.
3. To give you a well-known example. This was reported I think many years ago. I do not have link but I think it is easy for google search.
3.1 I believe it was about someone taking care of Sun storage. Here being about Sun and storage, it is a branded environment with proper build and technical skill I suggest. He discovered that by shouting directly against the storage gear, the I/O monitoring software shown an accompanying impact. [if the reference is wrong, my apology in advance]
3.2 Thus here the point is even for well-provision setup, shouting directly against the storage rack can impact the storage. When you think about home-build, you could be seeing a lot of variation in terms of overall vibration reduction demand.
4. I think some storage gears spend times to design many parts to reduce vibration in high density hard disk storage environment. However, I do not have any example to demonstrate. Perhaps those folks rich in such storage experience can detail.
Cheers
If you are putting together a package on the napp-it site for OI afp22, I'll pay for your Lion install. Let me know where to send you a iTunes gift card.
Gea
i turn on AFP and use lion to connect to the server via AFP and it works![]()
Cheers
- Nexenta or OI/SE11?
- Have you also tried Time Machine?
