Performance. If you are doing sequential reads, it can spread them over the separate vdevs.
Ahh yeah.
I hope by the time i need this some kind of defrag will be integrated in zfs
Hey... I have a problem when i try to install napp-it on openindiana 151 dev. I think it is because of a perl update.
see http://pastebin.com/VLeyqBQG
Thanks
I'm having problems getting my disk pinned down.
It works but the auto service is interfering with the device-treshold.
Now for me it is spindown or auto service enabled, as my drives are polled every 15min.
Actually it makes sense, but is there a way around it?
It would be nice to have an option to run things once a day or something, I don't know I don't understand the mechanics behind it.
It would be nice if both could be combined.
Hi,
Can anyone offer me some advice on setting up ZFS with my existing WD 4k 2TB drives?
I currently have 4 of them and using 3 in a FreeNas system setup as raidz with the 4th drive as a spare.
I plan on moving on to Openindiana and Napp-it. Reading through this thread makes me wonder if this is possible with my drives. I have installed OI and Napp-it and napp-it recognises the pool of drives, is it just a matter of importing them into the newer version of ZFS, if so how about the special formatting that FreeNas did for the 4k drives?
Because of the 4k problem is it wise to destroy the data on the drives and start over again with the newer version of ZFS?
Gea could you shed some light on this?
Sorry for being impatient.
I just moved my server to my new apartment and now its not reporting its hostname. Its connected to a Linksys E4200 via a couple gigabit switches, My ubuntu laptop reports its hostname properly but the solaris box doesn't seem to and I can't access it using the host name. Is there somthing I can do from solaris?
Thanks!
ps. Gea Napp-it is great!
Hmmm, is there a valid hostname set for the OI box?
Not sure where you are seeing the Smart OK thing? The top-level disks tab shows a field like S:0 T:0 H:0 that are the errors. What version are you running? I am on 0.500f.
Woudn't that be more dangerous and/or slower?Not as big of a deal. If you are going to use ramdisk, may as well just run with sync=disabled, no?
I should have been more specific sorry. I guess when I said more dangerous I was assuming a hard drive is more likely to die than the system crashing or losing power, but that may not be the case. As for slower, doesn't the ZIL soak up write I/O allowing your spindles to write sequentially?How so? If your ZIL is in ramdisk and the appliance crashes, your data is just as gone, no? Also, why would it be slower? The whole point of the ZIL is to speed up sync writes
The purpose of the ZIL (AFAIK) is to ACK a synchronous client write. The sequential write buffering is a basic part of ZFS - it delays writing data until (if possible) it can coalesce blocks being written. Still not sure I understand your danger concern? As far as I know if a drive fails and your poll is not redundant, you are hosed, whether you have a ZIL or not. If you are redundant, it doesn't matter...
Soft errors, Hard errors, Transport errors. More info if you click on the Controller tab.
