OpenSolaris derived ZFS NAS/ SAN (OmniOS, OpenIndiana, Solaris and napp-it)
Discussion in 'SSDs & Data Storage' started by _Gea, Dec 30, 2010.
  1. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    At the moment, I cannot reproduce your problem where Hipster adds a last login to the zpool or
    hostname command. Have you modified any OS settings?
  2. chune
    chune n00bie
    57
    Nov 2, 2013
    I may have run pkg update on this machine. Let me try with a fresh install again
  3. CopyRunStart
    CopyRunStart Limp Gawd
    144
    Apr 3, 2014
    Would just like to add to Gea's benchmarks.
    Solaris 11.3 Server with 20x 4TB WD Enterprise Drives in mirrors (direct wired to LSI cards). Intel X540-T2. Windows 10 Box with X540-T1. Sequential copies from Sol 11.3 server to Windows 10 Box were 450MB/s without jumbo frames. I think it could have gone faster but might have been limited by the write speed of the 850 Evo in the Windows 10 box.
  4. balance101
    balance101 Limp Gawd
    411
    Jan 31, 2008
    i'm having trouble install smartmontools on omnios r151016 - nappit v16.01f. I even try 5.4 and 6.3 version. Do i need other packages install? thanks
  5. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    OmniOS 151016 switched from gcc48 to gcc51
    The compiling process does not care at the moment.
    If you can't wait, install from
    http://scott.mathematik.uni-ulm.de/
  6. CopyRunStart
    144
    Apr 3, 2014
    Running Solaris 11.3 with latest Napp-it. I'm not sure if my Intel 750 NVME drive is working. I initialized it within napp-it and added it to the pool as a read cache but I'm not sure it's working. It doesn't show up in "All Known Disks and Partitions" in Napp-it. Is there a way to test an L2ARC device?
  7. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    OmniOS 151014+ and Solaris 11.3 support the Intel 750 NVMe disks what means that they are
    available for ZFS to create a pool onto or to use them as L2ARC or ZIL.
    This does not mean that other tools like iostat or smartmontools can detect them at the moment.
    If you want to check performance, create a basic pool from the Intel.
    I have done some performance checks lately with the Intel P750.
    They are very very good, see https://www.napp-it.org/doc/downloads/performance_smb2.pdf
  8. balance101
    411
    Jan 31, 2008
    thanks I installed smartmontools but on nappit it still says not installed and the smartctl command doesn't work?
    using the following commands
    Code:
    pkg set-publisher -O http://scott.mathematik.uni-ulm.de/release uulm.mawi
    pkg search -pr smartmontools
    pkg install smartmontools
    from http://wiki.openindiana.org/oi/3.+Installing+software+and+package+management
    Code:
    root@OmniOS:/root# pkg info -r smartmontools
           Summary: Control and monitor storage systems using SMART
             State: Installed
         Publisher: uulm.mawi
           Version: 6.3
            Branch: 0.151012
    Packaging Date: Mon Sep 29 13:22:53 2014
              FMRI: pkg://uulm.mawi/system/storage/smartmontools@6.3-0.151012:20140929T132253Z
    I checked if it was installed, it looks like it installed ok
    I try created the smartmontools file in /etc/default/smartmontools with the following contains
    Code:
    # Defaults for smartmontools initscript (/etc/init.d/smartmontools)
    # This is a POSIX shell fragment
    # List of devices you want to explicitly enable S.M.A.R.T. for
    # Not needed (and not recommended) if the device is monitored by smartd
    #enable_smart="/dev/hda /dev/hdb"
    # uncomment to start smartd on system startup
    start_smartd=yes
    # uncomment to pass additional options to smartd on startup
    smartd_opts="--interval=1800"
    and adding my the following to smartd.conf
    Code:
    /dev/rdsk/c1t50014EE2B6A43F25d0s0 -a -d sat,12
    /dev/rdsk/c1t50014EE2B6AC03AFd0s0 -a -d sat,12
    /dev/rdsk/c1t50014EE2B6B9E8F4d0s0 -a -d sat,12
    /dev/rdsk/c1t50014EE20B9C56B6d0s0 -a -d sat,12
    /dev/rdsk/c1t50014EE20B82D7B5d0s0 -a -d sat,12
    /dev/rdsk/c1t50014EE20BFFC2BEd0s0 -a -d sat,12
    /dev/rdsk/c1t50014EE20BFFD1F3d0s0 -a -d sat,12
    /dev/rdsk/c1t50014EE20C070DE3d0s0 -a -d sat,12
    /dev/rdsk/c1t50014EE20C168388d0s0 -a -d sat,12
    /dev/rdsk/c1t50014EE2614E6475d0s0 -a -d sat,12
    /dev/rdsk/c1t50014EE2614EFAD1d0s0 -a -d sat,12
    /dev/rdsk/c1t50014EE26154D4CEd0s0 -a -d sat,12
    still no luck :confused:
    should I use OmniOS r151014 instead of r151016? will smartmontools work on r151014?
    thanks
  9. gigatexal
    gigatexal [H]ardness Supreme
    7,217
    Jun 22, 2004
    Do you really need smartmontools for a SSD?
  10. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    I have updated the wget installer to compile the newest smartmontools 6.4
    and napp-it v16.01 p with a tuning panel for ip, system, nfs, nic and vnic (vmxnet3s) settings
  11. balance101
    411
    Jan 31, 2008
    did a fresh install of OmniOS r151014 and smartmontools 6.4 is installed no problem :D
    btw SAS2 extension for my supermicro backplane is very cool. mapped all the drive to the correct slot no problem and the locator red LED work! very cool :cool:
    Awesome work Gea, after few more testing and some tweaking I can start migrating my data off my OI nappit to new server ! thanks again for your help.
  12. balance101
    411
    Jan 31, 2008
    what's the best way to migrate data from Openindiana to OmniOS. Can thesystem see each other's zfs system since they're one same network? Do I need additional packages? thanks
  13. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    Both are Illumos distributions so this is easy. Think of Openindiana 151a as an OS that is quite identical
    to the first OmniOS release some years ago. Indeed OmniTi intended first to use OpenIndiana as
    base for their minimalistic enterprise storage OS but then decided against as there were too many
    dependencies with the full size desktop version. So they build their own from Illumos and it is now
    the ZFS storage server with the smallest footprint. Not just enough OS but just enough ZFS Storage OS -
    the main reason why OmniOS has a stable for years while OpenIndiana has not.
    If you want to migrate on the same machine, just install OmniOS and import the pool. If you want to keep
    OpenIndiana, use a new system disk ex a small 30GB+ SSD. If you want to transfer data between pools,
    do a ZFS send or a sync files with rsync or robocopy (Windows) that keeps permissions intact.
    If everything is ok, update the pool for newer features.
  14. balance101
    411
    Jan 31, 2008
    Oh nice, I'm thinking of making a copy of the data since I have space before moving physical hard drive over. Zfs send command the fastest way?
    update:
    running zfs send on OI to OmniOS now (don't know when it will finish)
    Code:
    zfs snapshot -r tank/data@fullbackup
    zfs send -R tank/data@fullbackup | ssh 192.168.1.143 zfs recv -vFd WD5TBX12/WD5TBX12DATA
    had a problem with ssh from OI(client) to OmniOS(server) "no common kex alg: client "
    fixed by adding the follow to OmniOS sshd_config
    Code:
    KexAlgorithms curve25519-sha256@libssh.org,diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group-exchange-sha256,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521
    just wondering it's starting to send snap on tank/data@2012-10-22 ? I made a snap just now? shouldn't it send tank/data@fullbackup ?
  15. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
  16. simbic
    simbic n00bie
    8
    Jan 17, 2016
    Hello Gea,
    I just moved my pool from OI to OmniOS. Running on an ESXI box. The main reason I moved was that napp-it crashed. I had to manually start it each time, and after a while I got a message in terminal that "software caused abort" or something like that. I couldn't browse shares through smb from my windows machines, but nfs still worked.
    So I installed OmniOS and moved my pool to that. Everything is working, but after awhile I get errors in the OmniOS console "setsocketopt SO_KEEPALIVE: invalid argument", causing smb to not work again. NFS still works. Restarting the smb service in napp-it makes it browsable and reachable again.
    I am at a loss here, I have no idea how to solve it. I've searched and searched and I am hoping you maybe can help me.
    [​IMG]
  17. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    First the source of above error is SSH
    You may stop SSH and check menu System > Log for other reasons
    If you update from OI to OmniOS and the problem remains,
    it reason may be located on your network or a client.
    Any special setup or anything curious there.
    You may also try an update to newest OmniOS 151016 as there are always continous fixes
    (There is a huge step regarding SMB in 151017 bloody, available in next stable around april)
    You may also switch between e1000 and vmxnet3 vnic to check if there is a reason.
    If you are not on ESXi 5.5u2 or 6.00u1, you may update to one of them.
  18. davewolfs
    davewolfs Limp Gawd
    333
    Nov 7, 2006
    Are people actually running Solaris on here? I can understand if you have budget to pay for a license but as an at home or small business setup I would not touch it.
  19. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    You can downlad Oracle Solaris and use it for demo and development for free
    you only need to buy a subscription for production use.
    Only problem is that updates and bugfixes are only available after payment.
    Although Solaris is the current ZFS server with the most and unique features like
    ZFS encryption and sequential resilvering (much faster), I use OmniOS as an
    attractive option for a Solaris based solution at home and for commercial use
    especially with the new SMB2.1 feature - and its free.
    I use Solaris but for demo and development only
  20. davewolfs
    davewolfs Limp Gawd
    333
    Nov 7, 2006
    Would never use Solaris because there are no updates unless you pay. You hit one bug you are screwed. It also doesn't work properly under ESXi unless you use OmniOS drivers and who knows how compatible they are.
    I'm pretty happy with OmniOS. Only a matter of time before they catch up.
  21. balance101
    411
    Jan 31, 2008
    my OI used 128k record size and my OmniOS uses 1m record size. with zfs send will the old data store properly under 1m record size?
  22. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    The very old OpenIndiana 151a does not support 1m recordsize while the current OpenIndiana Hipster do.
    I have not tried if zfs send preserves blocksize or use the parent settings.
    Try it.
  23. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
  24. gigatexal
    7,217
    Jun 22, 2004
    Are the multi user write degradations due to the copy on write nature of ZFS or a SMB 2.1?
  25. HammerSandwich
    HammerSandwich Gawd
    1,005
    Nov 18, 2004
    _Gea, you've often recommended Xeon E3s, citing their per-thread performance. This testing used 2x E5520s, which are significantly slower per thread. Did CPU load limit any of the results?
    Have you tested with E3s or newer E5s?
  26. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    I would say, the smaller part is due network collisions.
    Mostly its due concurrent read/writes to storage.
  27. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    I have used the above hardware as it was available.
    I have not done CPU tests but I doubt it would be too relevant.
    If you have the option, newer CPUs are faster and frequency
    is more important than number of cores.
  28. balance101
    411
    Jan 31, 2008
    it inherited the 1mb recordsize from OmniOS ;)
  29. calvinbui
    calvinbui n00bie
    31
    Apr 2, 2011
    Running some dd benchmarks, can anyone confirm if these are good?
    6 x 4TB WD Se in RAID Z2
    Code:
    Memory size: 16384 Megabytes
    write 12.8 GB via dd, please wait...
    time dd if=/dev/zero of=/hdd/dd.tst bs=2048000 count=6250
    6250+0 records in
    6250+0 records out
    12800000000 bytes transferred in 25.665755 secs (498719016 bytes/sec)
    real       25.6
    user        0.0
    sys         3.1
    12.8 GB in 25.6s = 500.00 MB/s Write
    wait 40 s
    read 12.8 GB via dd, please wait...
    time dd if=/hdd/dd.tst of=/dev/null bs=2048000
    6250+0 records in
    6250+0 records out
    12800000000 bytes transferred in 1.669509 secs (7666924629 bytes/sec)
    real        1.6
    user        0.0
    sys         1.6
    12.8 GB in 1.6s = 8000.00 MB/s Read
    And 2 x Samsung 840 Pro 512GB in a Mirror. Seems really slow for some reason :(
    Code:
    time dd if=/dev/zero of=/ssd/dd.tst bs=2048000 count=6250
    real     2:08.5
    user        0.0
    sys         1.5
    12.8 GB in 128.5s = 99.61 MB/s Write
    Finally I'm running an all-in-one on ESXi. Have a few questions about that too:
    1. Would iSCSI perform better than NFS as a datastore? I currently have a ZIL on each zpool which has worked wonders in reducing slow downs on my VMs. (25 mins vs 1 min for a simple system update on Ubuntu)
    2. Is it worth enabling Jumbo frames at all (and where should I enable it) for faster transfers between my VMs? No physical devices I own actually support 10Gbe, only the virtual machines running a VMXNET3 NIC
    EDIT: Here is iozone 1g benchmark performance...geez
    [​IMG]
  30. CopyRunStart
    144
    Apr 3, 2014
    I have 20 disks that used to be a part of a zpool but did not have the zpool destroy command used on them. Are they safe to use with a new zpool? Or is there metadata left behind on them that should be wiped?
  31. balance101
    411
    Jan 31, 2008
    So to install my 10 x 2tb from OI (i should do export) and install them to Omnios (i should do import) and it should be accessible ? without export will the pool get corrupted?
  32. HammerSandwich
    HammerSandwich Gawd
    1,005
    Nov 18, 2004
    Thank you.
  33. gigatexal
    7,217
    Jun 22, 2004
    I don't mean this to derail the thread, but I would have thought that NVME could handle many requests for both reads and writes.
  34. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    1. about the Z2 pool
    Sequential performance of a raid-z scale with number of datadisks.
    You have 4 datadisks, 500/4=125 MB/s per disk - as espected
    read values are cache values
    2. about writes to the SSD mirror
    I would check the SSD pool with sync=always vs sync=disabled
    the difference shows the sync write quality of the pool or the slog device
    If these are sync=disabled values, there is another problem
    3. iSCSI vs NFS
    Both perform similar with similar write settings (write back cache settings or sync)
    4. Jumbo
    Internal transfers between VMs over the vswitch are in software only.
    Performance depend on CPU, vnic (prefer vmxnet3) and vmxnet3 settings
    Try my tuning suggestions for vmxnet3.conf from
    http://www.napp-it.org/doc/downloads/napp-in-one.pdf page 30
    The other network related settings like ipbuffer and mtu are only relevant
    if you use a physical ethernet example for external transfers or a nic in pass.trough mode.
    To enable Jumboframes you must edit vmxnet3.conf and set mtu via ipadm
    Within ESXi you must enable mtu 9000 in the virtual switch and the management network settings
    For external use, you must enable Jumboframes in the switch and your clients.
  35. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    NVMe is Flash storage with a faster interface.
    In a multuser scenario performance degration is less than with a conventional
    enterprise SSD but of course there is one.
    The best what you can expect is
    - double performance for a single user compared to a conventional SSD
    - same performance with multiple users than a conventional SSD with one user.
  36. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    Don't worry
    Just import the pool.
    This works even without a prior export from OI 151 (older ZFS) to Omni (newer ZFS)
  37. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    Without a destroy ZFS may refuse to use the disks for a new pool as they are active members of a pool
    Options:
    - import and destroy the pool (even in offline or degraded state)
    - reinitialize or reformat the disks
  38. calvinbui
    calvinbui n00bie
    31
    Apr 2, 2011
    It was with sync=standard. I tried with sync=disabled and got the same result.
    I destroyed the pool and tested it again but still the same write speeds.
    So I created a basic pool instead of a mirror to test each SSD individually. Write speeds under dd bench with sync=standard were still slow (even slower, around 40mb/s each).
    I will report back when I test it with a clean install of napp-it and freenas to see if that could be the issue.
    However I must say in read world performance I did not see any noticeable slowdowns while running 20 VMs simultaneously.
    Code:
    write 4.096 GB via dd, please wait...
    time dd if=/dev/zero of=/ssd-Bd0/dd.tst bs=4096000 count=1000
    1000+0 records in
    1000+0 records out
    4096000000 bytes transferred in 113.319963 secs (36145441 bytes/sec)
    real     1:53.3
    user        0.0
    sys         0.8
    4.096 GB in 113.3s = 36.15 MB/s Write
    UPDATE: Tested on a new Napp-In-One installation but got the same slow results. May have to see how it performs under Windows or do some further digging. Hopefully just a ZFS thing and not my drives dying
    UPDATE 2: Ran some tests on my 2012R2 VM using CrystalDIskMark and Samsung's Magician Tool. Nothing seems to be wrong at all, only napp-it is giving me slow speeds. I will test on FreeNAS tomorrow when I get a chance. Here's an imgur album of both results. If it is a bug I'm happy to work with you Gea to fix it.
  39. _Gea
    _Gea 2[H]4U
    3,681
    Dec 5, 2010
    Are the 2012R2VM results from a VM with the Samsung over NFS from napp-it or via pass-through?
    What controller/ Firmware are you using with napp-it?
  40. TCM2
    TCM2 Gawd
    571
    Oct 17, 2013
    Wipe at least the first and last 1MB. If you can, wipe them completely for peace of mind, although it _should_ not be necessary.
