Years ago, there were discussions about race condition problems with RAM > 128 GB.
I have not heard of a "fix" but I also have not heard of current problems despite huge RAM is
today more often in use as 5 years ago.
Does a zfs send into a file not preserve checksums and everything?
It should make no difference if you send into a file or into a separate pool.
Hi gea,
this was on a omnios r16, and unfortunatly happend after a deluge install.
Tried removing Deluge, reboot, after that tried both given solutions , to no avail
Good discussion in this thread. Definitely check SirMaster's link in post #14.If I plan to run raidz2. What is the best number of drive per raidz2, It's mainly going to be storing media files. I'm thinking of buying 8 drives at a time. 8x 4/5TB (depending on sale) or should I go with 6 drives (6x 4/5TB). I want to optimize available storing capacity.
$ find /var/web-gui/data -type d -name IO -print0 | xargs -0 sudo rm -fr
Return of Perl error :
Software error:
Can't load '/var/web-gui/data/napp-it/CGI/auto/IO/Tty/Tty.so' for module IO::Tty: ld.so.1: perl: fatal: /var/web-gui/data/napp-it/CGI/auto/IO/Tty/Tty.so: wrong ELF class: ELFCLASS32 at /usr/perl5/5.16.1/lib/i86pc-solaris-thread-multi-64/DynaLoader.pm line 190.
at /var/web-gui/data/napp-it/CGI/IO/Tty.pm line 30.
both didn't work, any ideas ?
What went wrong?
ESXi burps when accessing iSCSI with 4K logical-block size. If you override the share to send 512-byte blocks, this error should go away. I'm not currently running Comstar & can't remember where that setting lives, but I bet _Gea knows.OK,
ESXi now can see the disks:
I simply went to the existing iSCSI adaptor and under dynamic discovery, added the IP to the omni box.
Add Datastore...
Then this happened!
So, I check the console for any errors,
Nothing!
Lets give it a reboot,
Now I can only PING the storage, but have no access to the web based console?!
Vmware will not locate the LUN after a rescan of the iSCSI adaptor.
What went wrong?
Finding this took a LONG time when I first encountered it. Not sure why it's so poorly reported online.
You can clear the screen with the command clear
