napp-it ver.: 0.9c1 nightly Jun.06.2013.
O/S ver.: SOLARIS 11.1
1) I can receive emails for job "status to -> Info", but do not receive any email for job " alert to -> Disk,Low,Job".
2a) Does napp-it install hdparm or other drive power management software?
-OR-
2b) How do I disable drive power management features on OS boot (AAM, APM & drive spin down)?
-OR-
2c) Does the other OSol (SmartOS, OmniOS & other) clones come with hdparm or other (advanced) drive power management software?
3) How do I setup a job in napp-it (or SOLARIS) to send an email alert, immediately when a drive fails or a pool is degraded (with drive & pool specific information)?
4) How do I setup a job in napp-it (or SOLARIS) to send me emails weekly/bi-weekly, with S.M.A.R.T. data of drives? (Hopefully this can be done as one email for each drive.)
5) Setup email notifications sent sen't immediately after (APC) UPS events (like brownouts, blackouts, over/under voltage etc) occur?
6) Lastly, I still cannot set CIFS/SMB permissions for USER1 to 'Full Access' & USER2 'Read-only Access' to the same shares! I have already tried this from within windows, as per _Gea's suggestions, but this method has not worked so far.
I have solved the following two endemic problems, after almost a year of struggling:
a) SSL/TLS email for email notifications/alert.
b) APC UPS driver compilation & installation. Now I can finally monitor (currently, only locally) & (have the system respond to) power events properly.
1,3
update to newest napp-it 0.9b3 or 0.9c2 (there was a problem with supress repeated alerts)
2. look at power.conf (OI, OmniOS as well, napp-it menu system Power Management for Illumos based systems)
http://docs.oracle.com/cd/E23824_01/html/821-1451/gjwsz.html
4,5. You need to create a script and start it as "other job"
6. Some Windows (non pro) do not work, use Pro editions, CLI (/usr/bin/chmod) or napp-it ACL extension
ps
If you have fixed some problems, please publish it here (post or add a pdf).
