Is there any way to set some of the zfs folder as hidden? like /folder$ to access
you mean shares?
zfs set sharesmb=name=Hidden$ tank/dataset
Problem fixed.
reload wget 09-updater
Hi,
I have 8 disk in my raidz2 openindiana/nappit machine.
I created the pool a while ago and started with e.g 1 TB and 1.5 TB drives. Now I have only 2 TB drives in the system. That's 16TB in total. with an ashift of 12
If I click on pool/volumes in nappit and it reports:
size 14.5TB, alloc 9.19T, Fres 100G, Free 5.31T. The exported volume using cifs to a windows machine report that it is a 10TB drive. Also df -h gives a size of 11TB.
I think that something went wrong with the auto expansion.
Exporting and importing the pool did not help. Also what not helped was doing eight times the following: zpool offline pool disk followed by zpool online -e pool disk.
Is there anyone who has idea's on how to correct this?
Many thanks
Yo,
Do I need to go in maintanance mode in ESXi to be able to update Napp-it?
My OI can't connect to the internet! I can reach all my pools though so it's not a network problem!
gr33tz
Hi,
Looks like napp-it 0.9 is rounding up disksizes, my 1.5tb disks are now all 2.0tb
c2t1d0 (!parted) 2 TB via dd ok ONLINE aggr0 raidz S:0 H:0 T:0 ATA WDC WD1501FASS-0
c2t7d0 (!parted) 2 TB via dd ok ONLINE aggr0 raidz S:0 H:0 T:0 ATA WDC WD2002FAEX-0
c3t0d0 (!parted) 2 TB via dd ok ONLINE aggr0 raidz S:0 H:0 T:0 ATA WDC WD15EARS-00S
_Gea, what is the "app_complete" extension I am seeing under 0.9?
Maintanance mode will not help you. This is just useful for some maintenance tasks for ESXi itself and does nothing useful for the VM's running on the server.
Just because it is virtual does not change many of the normal trouble shooting steps you would take with a normal server. Check things like DNS settings as this is a common cause of internet problems if the machine is otherwise accessible on the network. try pinging from the OI server to local addresses and your default gateway and also to a known good internet IP address like find the address of www.google.com or similar(only some web servers respond to ping though so test on a desktop/laptop first). also check routes and default gateway settings.
Also note that some secure setups for SAN VM's put the SAN on a seperate network so that normal local machines can't access them directly. This seperate network would need more advanced network setups and extra routers to give it internet access. I doubt this is the case for you though.
Michael
cannot replace c0t5000CCA369C9AAACd0 with c0t50014EE206E0EA31d0: devices have different sector alignment
Arrgh!
One of my disks in a pool is failing but the configured spare does not kick in.
When I try to replace it manually with the failed disk, I receive:
Code:cannot replace c0t5000CCA369C9AAACd0 with c0t50014EE206E0EA31d0: devices have different sector alignment
This is SolEx-11 with napp-it 0.8l3.
The pool has been created from 3 two-may mirrros as vdev and ashift=9
Made of 6 Disks, 2TB each, 2x Hitachi, 4x WDEARs
The spare is a WDEARX .. it can be/was perfectly added to the pool as a spare.
What can I do?
....re-running my final backups now...do I need to take that pool apart?
TIA,
Hominidae
Thanks _Gea for your fast reply!
This confirms my initial thoughts.
..but why is it possible to add a disk as a spare that obviously would not fit the pool in the first place?![]()
_Gea,
Can you help out... I'm having a strange issue - My setup is as followed;
OI running napp-it latest sharing a pool via NFS only. permissions set as root=@192.168.0.1/24 datatstore/media using 777 (eventually I would like to run SMB and AFP)
I can mount the NFS share just fine in OSX both wired and wirelessly. Both stations can read/write to the storage just fine with some pretty awesome speedsMy issue comes when trying to connect to a WD TV Live streaming media player.
I can see and access the stores via the media player, however when I attempt to click on the content the unit just hangs. I've googled around and have found others with similar issues relating to the protocol used = udp. See Here: http://forum.wdlxtv.com/viewtopic.php?f=&t=7243 & http://ubuntuforums.org/showthread.php?t=1883338
Similarly what they describe is what is happening to me...
does this sound like an issue napp-it sending via udp ? is there a way to change to TCP?
to be sure you may reset ACL recursively to this setting for already created files
How exactly do I do that, sorry...
use the napp-it "reset ACL" option below the list of ACL
and select modify, this option is free in this extension
check files, folders, recursively
Hi guys, how do you clean up different startup opinions? Because I install&reinstall napp-it multiply times, I probably have 14+ startup opinions...
Thanks!
list systemsnaps (BE): beadm list
destroy: beadm destroy -F bename
Hello _Gea,
I tried to upgrade my napp-it to 0.9, I installed it by wget -O - www.napp-it.org/napp-it09 | perl, but after restart, access to http://ip:81 showed 404 file not found. Any suggestions?
Hello _Gea,
Sorry, I haven't been checking back on this and missed your question when you first posted it ... the Perc H310 uses a proprietary split cable that branches a single connector at the controller end into two right-angled SFF-8087 cables that attach to the SAS backplane. We replaced that cable with two LSI straight through SFF8087 cables, attaching an LSI 9211-8i to the Dell backplane SFF-8087 female connectors instead of using the built-in Dell Perc H310. All the Dell drives (we have 8 2tb nearline SAS drives) show up under the 9211-8i BIOS and are usable. Unfortunately, however, the SFF-8087 cables stick up on the backplane end and would have to be folded pretty dramatically to fit under the cover (we have the R720xd mounted in a rack with the cover off). LSI sells right-angle 8087 cables which we first purchased, but the right-angle connector is oriented in the wrong direction for use with the Dell backplane and we had to replace those with straight through cables.Can you provide more info on how you resolved the cabling? I am stuck with a R720xd with an H310. Dell has acknowledged that it has a JBOD performance problem that they will not be able to correct in firmware so I am looking to do like you did and use an LSI 9211-8i card in IT mode. You can see me post in their forums with more details (http://en.community.dell.com/support-forums/servers/f/906/t/19480834.aspx) on the issues I ran into.
I have not looked inside yet, but were you able to connect the add-on drives in the back directly to an LSI card? Dell made it sound like it was proprietary. Would a 9211-4i do for those?
thanks.
I'm currently running Solaris Express 11 (SunOS 5.11, snv_151a) and napp-it 0.8 but I see that Solaris is no longer supported by napp-it.
Should I upgrade to OmniOS? ("stable" sounds better than OpenIndiana developer releases)
If so, is there any document or anything explaining what I would need to do this?
Thanks!
(EDIT: I'm running under ESXi 5.0 in case that matters...)
Thanks Gea!
You said that you use OI Live, but it can also be installed, right?
I'm looking at OpenIndiana Build 151A5 Server... is this the correct version?
Also, my pools are showing V31, so I can just do an import into OI?
