Private Citizen
- Mar 15, 2002
Looking for opinions on Openfiler in a production environment. We are a small county gov so we don't have the budget to really do some of the things we might would like to do sometimes, however we do have money to buy a couple of entry level SANs (Equalogic) but being me I'm always looking for perhaps a better way to do things, and cheaper also.
I've used Openfiler in test environments and it seems adequate but I've never used it in production. We have three vsphere boxes running local storage at one location and we are looking to use HA and vmotion so shared storage is needed.
I've thrown around the idea of maybe buying a Dell R710 filling it with TB disks and then using Openfiler. This setup would save us about 7k compared to an Equalogic solution. We want to have two SANs doing replication and both Equalogic and Openfiler can do this from what I've read.
Basically looking for the following info:
1. Do most folks run two SANs for DR and HA uses?
2. Is Openfiler a real viable solution for production?
3. We have the budget to buy two Equalogic SANs if needed.
4. NFS as opposed to iSCSI which I've used in the past? Pros Cons
5. Does Openfiler do true iSCSI now?
6. Anyone using Openfiler or OpenNAS in production?
