A PIX can be configured as a traditional IPSec VPN. Most of the the time however, client mode VPN is configured to use the Cisco VPN Client, which uses a couple proprietary techniques. If you are trying to get around lack of x64 support, they only way I could find when I tried several months back was to install the client in a virtual machine.
OpenVPN is entirely different than IPSec. You are going to need to find an IPSec client for Vista x64.
A couple minutes searching turned this up, which talks about the Draytek IPSec client for Vista.
The problem is that the standard way a PIX/ASA implements a client mode VPN will only work with their VPN client.
Damn proprietary losers!
We use a Juniper VPN at my job; they don't have a Vista x64 client either. I didn't bother trying other IPSec clients. I just convinced the IT dept to let me set up an OpenVPN box.
