HeavensCloud
Oswego, not shitty as Buffalo
- Feb 7, 2008
Nice work
will this work with unlocked amd cpu's?
it will work the same as any other temp monitor.. the problem with the unlocked dual/triple cores is not the monitoring apps.. its the fact that unlocking it disables the diode temp sensor..
I don't really know what you mean with "customization like CoreTemp" or "more aesthetics". If you can be more specific, maybe I can do something in a future version.
You know what would be AWESOME! Get it to display the information to the LCD to the Logitech keyboard. That will kick some butt! Nice program btw.
Looks like HWMonitor rather. But that totally depends on which came first.Looks like Everest TBO.
The tree-view GUI design has been implemented similar to the CPUID HWMonitor, although others have used similar GUI layouts before. Some of the resemblance of the current version of the Open Hardware Monitor is also caused by the fact that the CPUID HWMonitor started using the CPU and the temperature icon I designed for the Open Hardware Monitor. Also the mainboard node has appeared in the CPUID HWMonitor only after I added this to the Open Hardware Monitor.
