I built a 3570k HTPC almost 6 years ago using an MSI Z77A-G41 motherboard. I took the PC out to clean out the dust and noticed that the power supply I used (Antec Earthwatts 430) only had a single 4-pin motherboard plug and that's all I used, even though the motherboard has an 8-pin (4+4). It fit on the right side of the plug so apparently when I built it I plugged it in, said a prayer, and have never had a problem.
I am able to overclock the chip to 4.3 ghz, which isn't the best for a 3570k, and knowing I'm using a budget Z77 board. Do you think only using the 4-pin connector is causing me problems? Does the motherboard account for this? This power supply is about 10 years old and I can pick up a brand new EVGA BR 450 for $20, shipped.
Thanks.
Thanks.
