Scythe Infinity is actually easy to mount, it has stock HST mounting mechanism.
How about the infinity? any owners of Infinity love/hate it?
Any heatsink with a low-speed Noctua 120mm fan.
The Tuniq is quiet at 'Low' setting. 24/7 @ 3220mhz no need to max the fan even gaming. Yes the screw heads will tear off when forced too tight. It's meant to be hand tightened, it's good once it is heavy to turn. If it stops turning and you give it some more, it will snap like its a safety feature.
I ordered one for myself today with the Scythe S-Flex 1600rpm.
They've been released!!one
When did this happen?
But its best to perform the mounting mod found on xtremesystems, or else the Infinity won't make enough pressure with the IHSInfinity w. 2000 rpm TT fan, pentium D [email protected] GHz load 50 degrees, @4.0 GHz load 45 degrees. I think the mounting mechanism is easy to install but it requires some force to achieve proper contact. The grip is fine btw...
after reading the review @ anandtech I couldn't resist buying this. 70 dollars . the worst part is this jab-tech place is in oklahoma, only about 20 miles from me. The bad thing is I still had to ship it, and pay tax. Bleh no pickups. Anyway, I'll have to come back and post if it does well .120 extreme in stock:http://www.jab-tech.com/Thermalright-Ultra-120-eXtreme-pr-3762.html
