Onboard Audio missing after PCI-Express Card install
Discussion in 'General Hardware' started by Seluryar, Oct 4, 2018.
  1. Seluryar
    Seluryar Limp Gawd
    166
    Dec 8, 2011
    Installed an Orico USB 3.0 PCI -Express card for extra rear usb ports on my computer, Needed to update BIOS to get it to work, done that, found out that both my rear panel speaker and front panel headphone jacks werent working and did not show up in the sound panel/settings, All that showed up was my video card audio via Displayport.
    Even realtek drivers and software wouldnt work properly, I would install it, restart like it wanted to, but the audio manager wouldnt show up after restart. Perhaps its because the PCI card uses VIA drivers and they cant work with realtek audio drivers..
    Searched google to try and fix this and the main fix was to go into bios and make sure onboard audio was set from auto to enabled. This did not work.
    Removed the pci card and onboard audio started working just fine.
    Installed the card again to see if it was a fluke or something, Even reformatted my hard drive with a clean install of Windows 10, Still wouldnt work.
    The card worked fine with things plugged into it So I dont think it could be a bad part.
    Any ideas on how to fix this doozy of a problem?
  2. ryan_975
    ryan_975 [H]ardForum Junkie
    13,813
    Feb 6, 2006
    which motherboard? It's possible that they set it up so that one of the slots shares a PCIe link with the audio chip (though I've never seen that).
    pendragon1 likes this.
  3. dvsman
    dvsman 2[H]4U
    2,368
    Dec 2, 2009
    Looks like it's just sucking up the same resources as the audio. Look in UEFI / Bios and see if there are any options you can change in there. Otherwise it's like ryan_975 says - it's a hardware conflict issue and nothing you can do but change to another slot instead.
  4. pendragon1
    pendragon1 [H]ardForum Junkie
    10,735
    Oct 7, 2000
  5. Seluryar
    Seluryar Limp Gawd
    166
    Dec 8, 2011
    ASRock Z87 Extreme3
    Would I see any performance issues if I put my GPU in the other pci slot? Its MSI GTX 970 4G.
  6. pendragon1
    10,735
    Oct 7, 2000
    shouldn't. even if it drops to 8x(didnt look into that) you wont see any noticeable difference.
  7. Seluryar
    Seluryar Limp Gawd
    166
    Dec 8, 2011
    Tried a different gpu slot but the same thing happened.
  8. pendragon1
    10,735
    Oct 7, 2000
  9. Seluryar
    Seluryar Limp Gawd
    166
    Dec 8, 2011
  10. pendragon1
    10,735
    Oct 7, 2000
    no prob. glad you got it working.
