Hi all, bit of an issue.
I have built a SM storage server which has dual onboard NIC's, Intel X540-T2's. Mobo is an X9SRH-7TF.
My ESXi host has dual Intel X540-T2's as well.
OmniOS refuses to negotiate to 10Gb, only 1Gb. I am using, for now, a Cat6 cable between them, no switch. I am somewhat confident it's an OmniOS issue because when I connect the dual port nics on the ESXi box together, they come up 10Gb no problem. The Omni ports, always 1Gb. Could always be hardware though :S I am running the latest BIOS...
Any suggestions? The OmniOS box has the newest setup, I am not sure why the issue would be here unless there is something physically wrong with it.
It's not the end of the planet if I need to put on a different OS to test, the box is just in testing phase right now, but I really don't want to have to do that if I can avoid it.
