It looks like a friggen awesome game, so much of it is done so well, that's what makes it all the more dissapointing that it has such glaring flaws:
If you shoot propane tanks, they don't blow up.
You can't jump on top of an oil barrel?
You can't open a door? You have to wait for some other soldier to open the door, wtf is that, or am I just ignorant and can't find the "open door" command?!?
I just shot the guys on a truck with a .50 caliber mounted on the bed, why can't I A: get in the truck and drive it or B: grab the .50 and start blasting away??? Ugh.
I tried to run past where a soldier was pulling out barbed wire, before he had it in place, there was some kidn of invisible fence. Invisible fences don't belong in FPS games, they are a cheap shortcut out of good level design and annoying as hell.
I see grenades lying all over, but I can't pick them up, irritating.
I'll try shooting at the propane tank more to see if it makes a difference, but I shot it like 10 times and it was just one of those small ~2 foot tall ones you use for gas grills.
I guess I'll try playing a little more, but if there's not some way to fix these issues then I can't see how the game could be playable.
It sure looks cool though.
