I have two computers. One with the Audigy Gamer and one with an Audigy 2. I have an old (ancient) computer subwoofer (JBL) that was designed for two speaker only setups to increase bass. The 1/8" line goes to the subwoofer then there's an out line to the speakers.
(I have two of the subwoofers and they both do the same thing).
I've plugged the subwoofer only line (splits on the line 3 out between subwoofer and center) from the Audigy Gamer (later the Audigy 2) into my old subwoofer. I have to crack the subwoofer volume to 100% in the mixer and the subwoofer to get anything out of it. I've toyed with bass redirection and the levels to no benefit.
QUESTION:
Is it possible that the old subwoofer is only taking part of the signal from the dedicated line on the new soundcard and only processing that rather than the full outputted signal? Does the output on the Audigy produce only a low signal or is it a full signal that the newer subs use? Did that make any sense? I can't quite explain it.
QUESTION:
