References:
http://hardforum.com/showthread.php?t=1680769
http://hardforum.com/showthread.php?t=1685155
http://hardforum.com/showthread.php?t=1687729
I finished installing my XSPC Raystorm RX240 kit. Load temps went from 85(Corsair H100) to 73 degrees. I only used two gentle typhoons though(push configuration), I'll add two more for a push/pull configuration later.
This is a little gallery:
Corsair H100 removed
And put away for later use. I will use it for my QX9650 rig.
I used an unused PSU laying around for running the pump to fill the loop with the coolant.
This is the knife I used to cut the tubing! hehehehe
And this is the loop running and getting rid of air bubbles. You can see that the coolant is little whitish because of too much air bubbles.
The room was sure a mess
Thanks God wife was away!
The loop finally inside my level 10 GT.
And I was barely able to fit the two Gentle Typhoons...My case wasn't big enough for this thick radiator I guess.
By the way my 2700k didn't exceed 52 degrees @ full load with the stock settings.
So what do you think? Any comments? Am I within the acceptable range of this Extreme kit performance?
I intend to remount the water block and use the cool silver thermal pad and see if that improves temps. Good or bad idea?
Before I go, I must say thanks to all those who helped in this. To name a few:
Tsumi, Skripka, JLangevin, and K1tty......
