I dont know if you read my previous post, but speedfan was showing my northbridge temps at around 120c (aux temps) I had my 6400 overclocked to 3.2ghz, I actually put by hand on the northbridge heatsink and it burns your hand when you touch it!!I then quickly went to bios, restored defaults, and temps are staying the same! I need help fast before the mobo burns out, what could be the problem!!Mobo is a p5b-e, i have 2 case fans and a scyther infinity on cpu. Idle cpu is around 40c and system temps around 42 please help!Unless speedfan is reading it wrong and the northbridge should be hot to touch?
