postcd
- Nov 24, 2016
Hello,
i read the https://www.delidded.com/lga-771-to-775-adapter/4/ showing it is possible to use socket 771 CPU on 775 motherboard. I checked motherboard FSB to match my CPU and motherboard max CPU TDP to support it.
MB: Gigabyte GA-EP45-UD3R rev. 1.1 (socket 775)
CPU: Xeon E5430 (stepping A) (socket 771)
On the CPU was already a thing that seemed like a 771->775 reduction... so i just cut away two parts of the 775 socket to fit that 771 CPU and started computer after seating the heat sink and connecting FAN cable, all seems to work.
Issue is the CPU temperature is higher (maybe because i was unable to click one of the FAN PINs to the mothrboard and i left old thermal paste as it seems liquid and i do not have new paste. The temperature is like 60C when relatively idle, but like 85-90C under heavier load. I see on ark.intel.com that maximum temp. is 67C - "Case Temperature is the maximum temperature allowed at the processor Integrated Heat Spreader (IHS)." (i do not understand that description what is integrated heat spreader and how to know its temperature)
Is it too risky to use the computer until my thermal paste arrive in like one week?
Is it possible that detected temperature is wrongly interpreted by motherboard that do not know the CPU somehow?
(I see temperature figures from SW called Speccy and CPUID HW monitor.)
