hello all
anyone know where i can get some nice 19*12 backgrounds.
Thanks
This monitor can do 1920x1200 over VGA if you connect to your computer. My monitor can not do 1920x1080 if i connect to my xbox360. I can select this but the monitor shows 1680x1050 max. resolution.
Rentux
If it was possible to use xbox360 with a resolution 1920x1080 over VGA before firmware update, maybe somebody (without firmwareupdate) can post standard timing identification
using the ViewSonic EDID Utility.
Does component give you the same result, no 1080p?
So I just have to ask, recently in this thread, there have been numerous reports of problems with this monitor, so why are people still praising it?
Red saturation. <-- this is a HUGE problem, why do people not seem to care?
VGA problems.
HDMI and component displays black bars on all four sides with 1:1.
PIP is essentially unusable.
Maybe it would be better to wait for a superior monitor without these problems.
VGA problems.
From the pictures a few pages back, the red saturation problem on VGA was hugely noticeable and horrible. Just compare it to the DVI image. The problem isn't that the monitor is slightly warmed or cooler. The thing is just so bloody red/purple from the pictures posted here compared to the DVI image.
PIP is essentially unusable because it separates into two groups (VGA, DVI, etc.) and (S-video, etc.) If you look at the PIP on the Dell or Gateway for example, this is not the case. Sure, you can get PIP on the BenQ technically, but it's a gimmick (I wouldn't really consider it fair and true PIP like the Gateway's).
This is the picture:
Purolator tracking says
Status On vehicle for delivery
Date/Time FEBRUARY 12, 2007 AT 07:41
Depot OTTAWA, ON
Still waiting. I hope Purolator will not fake delivery like they have did once to my building and have me fetch it at their office. I'm staying by my phone and they better ring the building door.
Well in reading a few pages of this enormous thread my question is going to be with all pros and cons of this monitor..
I have a question.
Is it worth buying spending $900 on this monitor or would it be more wise to get a 22"
Samsung 206BW Samsung $380
Display Technology TFT active matrix
Display Diagonal Size 20 inch
Display Response Time 2ms
Image Contrast Ratio 2000:1
Max Resolution 1680x1050
Or Samsung SyncMaster 226BW 22IN $487
Price isnt the issure. I just want the better quality . So far Ive heard good and bad about the Benq and then again we have Samsung monitors which are half the price (22") as well but seem to do great in reviews.
Thats why I want to know from people here since this is my first LCD purchase, Which would be the better buy? and why?
And viewing purposes : Gaming, Photopshop, General Web surfing.
Still not here. That thing has spent the last 6 hours on the Purolator truck in -14C temperature. It will be frozen solid when I get it.
Damn, Gridneo, by the time you give it it will be outdated! Send it back for another update
