Read page 44 of the Manual. 1920x1200 60Hz maxmaarek99 said:Anyone else have 1920x1200 at 75hz? I can only get 60. Someone?
SteveW928 said:A number of pages back, there was a link to a review site that compared the Z to the W. Although, it is still not clear if it was an actual production model or not... I'm not sure I really don't want the Z yet, even if I was willing to spend the extra money. The Z looked a bit like a downgrade to me (colors were worse I think) from that review. Hopefully we'll see some more reviews on actual shipping models.
MaJ-ReD said:I don't know if this is true or not, but have read on a few websites that they used a lesser quality LCD panel for the WZ models?
Can anyone confirm or deny this claim?
kadiir said:Somewhere in this thread it was also pointed out that no WZs had shipped out from the production line - only samples (at least, at the time of the BE review).
1920x1200x75Hz exceed the bandwidth specs of the SL-DVI. And the monitor will not utilize the DL-DVI nor I suspect does the input chip on the monitor able to process it.maarek99 said:Anyone else have 1920x1200 at 75hz? I can only get 60. Someone?
darklight_tr said:So, the quality of the FP241WZ should be exactly the same as the FP241W with the bonus of having AMA Z (BFI). 1:1 pixel mapping and aspect control has been confirmed in all shipping versions of the FP241WZ as well.
Askanison said:1920x1200x75Hz exceed the bandwidth specs of the SL-DVI. And the monitor will not utilize the DL-DVI nor I suspect does the input chip on the monitor able to process it.
SteveW928 said:Hehe.... besides that, I'm trying to figure out why they would want to drive it at 75hz. Scan rate (for the video card for a CRT) does not equal frame rate (which would be more dependent on what software.... ie: game, movie, etc.).
Sycraft said:SteveW928: Because it's NOT a defect. When something doesn't have a given feature, that's not a defect, that's a choice. Not all products have all features. The FP241W is no more "defective" than a monitor that doesn't have an HDMI input, or PIP.
Yup, you'll probably get jerking, streaking and tearing with PAL material unless you use a refresh rate which is a simple multiplier of 25. 60Hz is OK for N. American users, as NTSC broadcasts use 30fps.maarek99 said:Because pal video material is 50 fps. That means when I watch it on my BenQ fp241w at 60hz the material is jerky as it can't fit 50 to 60. A 75hz refresh rate would be way better and decrease the jitter. Pal movies also playback at 25 fps and that fits perfectly under 75hz.
Not so hard to figure out. I was asking because a couple of advertisements showed that it should be capable of 75hz at 1920x1200, but I guess they lied.
BrokenAnimator said:Quick fact check here guys:
Pal is actually 25 frames per second. Interlaced would need 50hz refresh rate.
NTSC is 30 frames a second, interlaced would need a 60hz refresh rate.
http://en.wikipedia.org/wiki/576i
SlyNine said:NTSC may be 30 FPS, but almost any movie is shot originally at 24 fps. witch neither will fit in 50 or 60 very well. But if you don't notice it much on a DVD player. then it probably should not bug you too much on this.
SteveW928 said:Yes, but LCDs don't 'scan' like a CRT does. So, other than how the signal processing circuitry wants the input signal... I think this should be irrelevant.
then you're seeing 24 fps. If you're playing some 1st person shooter with a frame rate of 90 fps... then its 90 fps.
I might be clutching at straws now, but is your cable itself dual link (the connectors have 24 pins in three rows of eight, as opposed to two seperate blocks of 3x3)?maarek99 said:edit:
Nope, I have dual link dvi at both ports, the benq doesn't support 1920x1200 at 75hz.
Yes, you're quite right, I was looking at the horizontal frequency before. Damn.kadiir said:I was looking at the manual PDF and while it says in the features it supports up to 75Hz, if you look at the list of resolution/refresh settings, it shows 1920x1200 only at 60Hz.
I'm hoping it will work, too, as I'll be getting one soon (with the 1:1 fix).
Hey does your model has 1:1 features on it? BenQ has released a firmwire update which adds 1:1 features and it's supposed to be in a "new batch" of LCDs...NightWolf88 said:Hey,
Just got the BENQ FP241W for xmas, and its a great screen!!! Its so huge, comming from a 19" LCD i was amazed at the size of a 24" screen.
Any ways, I was wondering what people that own the monitor find are the best settings for a PC DVI input??? I.E color, mode (I find that anything other than standard mode is blury for text on the screen), contrast, brightness etc etc...?
If your looking for a great 24" screen I would def go with this one... Very very very nice screen, colors are very deep, FEAR looks great cept to run the 1900x1200 res Im finding my 7800GTX a little out of date Installing Splinter Cell Double Agent now to see what the blakc look like...
Also does anyone have any images to test the screen, and look for dead pixels???
Thanks,
NW
BrokenAnimator said:huh, I am not sure what your getting at.
Movies are shot on film at a 24 FPS exposure time, or 24 FPS with HD camera's but they are not interlaced they are progressive. They are then converted to NTSC or PAL through the 3:2 pull down method.
Don't confuse Frames per Second with interlaced fields they are two different things. 60HZ refresh is enough to properly display interlaced NTFS or PAL. Anyways I digress.....we need to go back on topic of the Benq fp241w.
SlyNine said:You have the original source shooting at 24 FPS. So no matter how you dice it and display it you are putting 24 FPS in to 30 or 60 FPS. or 50 with Pal
And id like to know how you think i got FPS confused with Interlaced fields. I was simply saying the NTCS gives you 30 Full Frames Per Second on standard 480i.
Yes I do understand the exposer time causes a blur that does make this less noticeable. But my point still stands.
BrokenAnimator said:Your still getting fields and frames confused. Also it's NTSC not NTCS and exposure time does not cause blur pertaining to our subject at hand, film is progressive, you get strobing with film but thats another subject. The reason for flickering is because of the interlacing process. Pal is 25 Frames per second, Interlaced would mean you would have 50hz field rate. Read this article: http://en.wikipedia.org/wiki/576i
Then read this: http://www.hometheaterhifi.com/volume_7_4/dvd-benchmark-part-5-progressive-10-2000.html
That will give you a better understanding of what I am talking about. That should help you out.
SlyNine said:I completely understand the difference between Fields and Frames.
And again the exposer time does in fact cause a blur , And it does in fact make the interleaved video less noticeable. And that is in fact what i was talking about.
And FYI. I did read that article long before reading this forum.
And what I am saying is that. You have originally 24 FPS, You then cut it up in 2 Interlaced fields for TV's. then the DVD player takes the fields and sends them to the TV. SO you have 24 FPS ( call it fields.. or frames I don't care ) being displayed at 60hz/FPS
And the flicker can be caused by more then just the Interlaced fields switching back and forth, glow rate and the time between scaning the 2 fields can cause the flicker just as well
If you want to consider what you see in a theatre a strobing effect rather then a flicker , By all means.
BrokenAnimator said:What can I say, your wrong, plain and simple. Please re-read the posted links to understand.
Your not understanding the difference between progressive and interlaced fields. Dosen't matter though, lets get back on subject here.
Thanks,
NW
ALL I am saying is that. If DVD played on a TV does not bug you too much. Then why would PAL being played on this monitor bug you.
