notorious hsg
- Oct 9, 2006
man this thread has slowed down to a grinding halt!...... cmon guys surely you'd like to share your benQ goodness with the world.. how bout some pics? Xbox 360 pics and PC gaming pics...
Apparently according to tftcentral the Z model won't have 1:1 scaling eitherGridneo said:with some verifications that it will get fixed when the Z model comes out...
the option referring to said 1:1 scaling.Note: the forthcoming FP241WZ will also be without this option.
[omen] said:1080p Quicktime trailers look AMAZING on this thing. My comp doesn't quite have the horsepower to keep up with the frame rates (gotta upgrade), but the individual frames themselves are just ridiculously good looking.
cb474 said:What sort of specs does it take to drive the frame rate for 1080p movie on a monitor of this resolution? Is this more of a graphics card issue or a processor issue?
I'm thinking of using this monitor with a Dual 1Ghz Mac G4 and a Radeon 9000 Pro graphics card. So it's not the newest computer. Thanks for any thoughts.
There is a know issue with the HDMI port on the dish box call tech support to verifyI'm using a monoprice gold plated DVI->HDMI cable form my dish to the FP241W and get blue sparkles even when the DVR is paused. sparkles indicate dropped bits and is a common problem on the Westinghouse LCD TVs. An example can be seen here.
mysteryman said:omen,
have you tried the utilities and/or massaging to re-vive your 2 dead pixels?
peTeMelster said:Omen, can you post screenshots of VGA and DVI picture, so we can see the quality/sharpness difference?
DarkAngel_ZERO said:Here's the list of requirements for Quicktime 7 on both Mac and PC. Sounds like you might come up just a bit short of 1080p, but just fine for 720p.
http://www.apple.com/quicktime/guide/hd/recommendations.html
DangerIsGo said:Ill be getting an upconverting DVD player this friday so I can test the 1080i via HDMI. no testing with full 1080p via HDMI yet. but ill post pics then.
cb474 said:Thanks for the link. What about other media players? VLC? Mplayer? Would they have the same specs as Quicktime? Can they display 1080p?
peTeMelster said:I was thinking of actually pressing the screenshot button on your keyboard, then pasting it into Paint or something instead of taking pics with a camera. Wouldn't that show the true quality of each connection?
Thanks for these pics though.
SPEEDMAN said:hi,
has anyone gotten a confirmation of a reliable source wether or not the Z version stretches the images as well ?
what else are the differences between not-Z and Z ? I read BFI, what is BFI ?
sry i'm noob at that.
The reason widescreen games are stretched vertically has to do with the difference in aspect ratios. Widescreen content in the video world has an aspect ratio of 16:9, whereas widescreen computer displays have an aspect ratio of 16:10. This subtle difference means that your video source will only be stretched vertically, thus converting the vertical aspect of 9 to 10 (the width aspect of both your video source and the monitor is 16, so there is no need to stretch horizontally). This conversion has been said to lead to characters on screen having "giraffe necks", such image deformation is why discerning users prefer displays which have a 1:1 display capability.redman223 said:As for hooking up consoles to this monitor, has anyone noticed that all games get stretched to widescreen, and when you enable widescreen in games that support it, everything seems stretched out vertically? I did my testing using God of War and Killzone for PS2, and each appeared stretched out vertically when I enabled widescreen. I tested both games using both component connections and s-video. I noticed that s-video displayed the menus clearer than component when in 480i, but in games that support progressive scan, 480p on component looks much better.
An upscaling DVD player will provide a higher resolution video source, meaning that the image stretching would not be as severe. Both HD-DVD and Blu-Ray are 1080p video sources, therefore the only stretching that will occur is the purely vertical stretching I described above. The only way your video card could prevent said stretching is if it created a "letterbox" effect to contain the 1080p content and use black bars to fill in the remaining pixels.redman223 said:I was planning on buying an upscaling DVD player, but since someone already said it stretches everything, including HDMI sources, there is really no point in me buying one now. However, by using the video card to scale things, that should let me view 1080p correct? Same goes for when I buy either an HD-DVD or Blu-Ray disk drive in the future right?
thank you, much obliged.Badd said:Aspect ratio options and 1:1 pixel mapping are NOT listed in the manual for the FP241WZ and i really don't think the option will be available sadly. The only change is the addition of BFI technology which is their Black Frame Insertion designed to help reduce perceived blur in motion on LCD's. Some more info about the FP241WZ and a section about BFI available here![]()
Robstafarian said:An upscaling DVD player will provide a higher resolution video source, meaning that the image stretching would not be as severe. Both HD-DVD and Blu-Ray are 1080p video sources, therefore the only stretching that will occur is the purely vertical stretching I described above. The only way your video card could prevent said stretching is if it created a "letterbox" effect to contain the 1080p content and use black bars to fill in the remaining pixels.
