Furious Salesman
- Aug 31, 2007
I am not an electrician but isn't a hum natural to electronics?
There is no gamble. Just order FP241W online and make sure to tell them you want a September built, shown right on the box.
For anyone wondering...
I recently ordered a FP241W from NCIX.com (this site was actually like $30 cheaper than NCIXUS.com and they still ship to the U.S., weird, I know). I ordered on 11/29/07 and just received my monitor today (12/6/07). I received the September 2007 monitor. During the checkout process, there is a text box where you can free-form enter any text (both for the warehouse as well as shipping. I put in there: "I will only accept this monitor if the date of manufacturing is Sept 2007 or newer, please check the box"
It worked! My total price (including Express Coverage - with "ZERO Dead PIXEL" Exchange and shipping with insurance) was $634.75
By the way - I just checked. Base price of the monitor from NCIX.com is: $559.48 and from NCIXUS.com is $582.96. Shipping is the same price. Odd.
OMG you ordered yours 5 days after I ordered mine and mine still isn't here.
STUPID NCIX.
I'm so upset.
Rawr.
Dang, so someone had a blackout using a newer 8800GT. That's not good, but others with 8800GTS/GTX/Ultra cards aren't experiencing this yet.
Different PCB, so maybe it's just the 8800GTS/GTX/Ultras that are being lucky?
I hope mine doesn't blackout.
Anyone want to access the service menu and check which panel they got from NCIX's Sept 07 batch?
press
the "POWER", "SELECT" and "MENU" button at the same time.
After on lcd monitor, press the "v" button, now you can login to the
factory service mode.
The bottom Line should state the PANEL info.
I am curious to know which AUO panel this monitor uses before I pull the trigger thanks.
Dazog,
Q24W5AXX MCEV020 0517 USA
Thanks!
Dazog,
Here's what mine states: (not sure if this is what you are looking for)
Do you have the ViDigi cable with you? It should have come with instructions.
The cable has one green striped component plug. Put that into the corresponding component input. Switch your monitor to component input and switch the wii on. The image should come up as black and white. Then go into the wii menu and set the Wii to 480P and 16:9 aspect ratio.
You can take the component plug out. Since the wiiga cable ends with a female vga end, you will need to get an adapter or another regular vga cable and hook it up between your Wii cable and monitor.
Here comes some weird stuff. On the end of the Wii cable where the blue led is should be a little switch box. There are either 4 or 5 switches. There should be a sticker there that shows various settings and tells you witch switches need to be on or off.
The default config should be fine. Turn your Wii on and the wii menu should come up and should display in 640x480 resolution.
The menu may show up off center. Just hit your auto adjustment once and you should be fine. Don't hit it too many times or it go off center again.
Hopefully this helps you out. One thing I noticed with my cable is some sharpness artifacts in the Wii menu (not in game). If you have a sharpness adjust I would tone it down a little.
Yep that's the one. I had basically done what you said but my image get pasted to the top of the monitor with a big black bar on the bottom. I have to use the "FULL" mode aswell. Wth won't it work with aspect?
Okay I'm an idiot, figured out the 1:1.
Haha.
LOOKS AWESOME!
Do NCIX.com and NCIXUS.com get stock from the same warehouse? I want to ensure a Sep2007 monitor but NCIX.com doesn't accept US credit cards only paypal (sucks). Should I get a crappy paypal account or just order from the US site?
......I told him to try IE7, or firefox, but he's too lazy for the time being.......
I have a PS3 hooked up to my BenQ FP241W with an HDMI cable at 1080p and there is a setting for having the RGB set at Full or Limited.
The default is limited but on some displays, it apparantly should be set to Full.
This is from the PS3 manual:
-Limited is for when RGB output signal is output in the range from 16 to 235.
-Full is for when RGB output signal is output in the range from 0 to 255.
-Hints: If black sometimes appears bright and sometimes appears pale on the screen when [Limited] is selected, set this option to [Full]. If black appears dull on the screen when [Full] is selected, set this option to [Limited].
Does anyone know what setting I should pick for my PS3?
I also have another more complicated question re: a PS3 setting when using the PS3 on this monitor. There is an option called "Y Pb / Cb Pr / Cr Super-White (HDMI)" that is described as follows "Adjust output settings for TVs that support Y Pb / Cb Pr / Cr input signals. Super-white signal can be output when playing a DVD, Blu-ray Disc (BD), or AVCHD-format video. This setting is for use when the TV is connected to the PS3 system using an HDMI cable." The setting options are as follows "Off = Disable super-white output and On = Enable super-white output." Finally, here is some further description in the manual: "When this function is set to [On], content from AVCHD-format video files recorded in x.v.Color / x.v.Colour can be played with a wide color scale. x.v.Color / x.v.Colour is a trademark proposed by Sony as the name to be assigned to devices that support "xvYCC," which is an international standard for color space in moving images. An advantage of x.v.Color / x.v.Colour is that it can reproduce a wider color scale than the conventional standard."
Thanks for any help.
