I was able to OC my 2500k on Asus p8p67 pro to 100x48. It was linpack stable for 2 hours but bsod after 1 hr of gaming. Should I try some other method of testing CPU stability?
Try IBT, it seems to be able to stress the CPU harder than LinX can.
Thanks for the Guide.. Need Help
I was able to Overclock to 4.8 at 1.425 following the guide as-is. I'm stable with IBT but crashes in 5 min with Prime95 I saw couple of poeple successful stable with Prime95.,
My specs
i7-2600k
ASUS P8P67 Pro Motherboard - 1204 bios
Memory : 8GB DDR3 (4Dimms with 2GB each) 1333mhz 9-9-9-24 CL9 http://www.patriotmem.com/products/detailp.jsp?prodline=5&catid=23&prodgroupid=71&id=765&type=1
Power Supply : Ultra ATX 600 watt.
Xigmatek HDT-S1283 Cooler
Do you have PLL overvoltage on? Have you tried raising VCCIO or VCCSA - I found raising those a notch helped me get Prime stable at 4.8
Just spent the night reading through a number of threads/articles online and finally took the dive and tried my hand at OC'ing. This was after I re-applied my Noctua TIM with a new spread method to ensure lowest temps.
I started out at 4GHz, but decided to try for a stable 4.5GHz 24/7 OC:
Thats with the following settings:
AI Tweaker:
AI Overclock Tuner - Manual
BCLK/PEG Frequency - 100
Turbo Frequncy - Enabled
By All Cores (Can Adjust In OS)
Internal PPL Overvoltage - Auto
Turbo Ratio - 40
Memory Frequency - 1600MHz
EPU Power Saving Mode - Disabled
Load-Line Calibration - Ultra High
VRM Frequency - Manual, set to 350
Phase Control - Extreme
Duty Control - Extreme
CPU Voltage - Manual
CPU Manual Voltage - 1.28
DRAM Voltage - 1.5
DRAM Timings:
CAS Latency - 9
RAS to CAS Delay - 9
RAS Pre Time - 9
RAS ACT Time - 24
DRAM Command Mode - 2T
The rest of my settings are default - any adjustments you think I can make? Are my temps ok (Do live Australia where its bloody hot atm)? I'm concerned why 2 of the cores have quite different temperatures - did I stuff up TIM application?
It should be fine, there are reports of people running the engineering samples at 1.45v and over for months with no problems.
Disabling C1 C3 and C6 doesn't actually make it idle at the overclocked frequency btw, it just doesn't report that its idling at 1.6ghz to the OS anymore. CPU-Z shows 5ghz, but Tmonitor shows 1600mhz. Seems likes theres no way to make it idle at an overclocked frequency.
disabling all cstates and speedstep actually does keep the cpu at the oc speed when idle. just as the guy who wrote the "Ultimate Sandy Bridge OC Guide" on overclock.net said - "tmonitor is just a POS". it shows lower multiplier to his i7 930 too. so i went and checked it myself. indeed it shows 6x instead of 10.5x on my e7400 when idle. so forget about tmonitor, trust your cpuz
i also confirmed this from realtemp3.67. it shows the cpu speed steady @ 4.8GHz and idle power is about 30w when all disabled. but when i enable all, the cpu speed would fluctuate and the idle power is down to only about 6w.
i went further doing some benchmark, it does show a difference, altho very small. (scores lower when all enabled).
Did you try checking power at the wall, that would eliminate any possibility of CPU-z or Realtemp reporting wrong.
i don't have a wall power meter to confirm that but i can certain say tmonitor is reporting wrong
also, i did see some difference in benchmark scores between enabling and disabling the cstates and speedstep. win7 index, heaven2.1 and diskmark showed higher scores, superpi stayed the same.
Why would diskmark be affected by C states? Or was your sentence structured to show that you turned off indexing, and that caused the slowdown in diskmark?
maybe because the cpu is in fact running at full oc speed even at idle? actually, diskmark scored a little higher only on the 512k: 185.1 read/ 166.5 write vs 178.5 read/ 135.4 write. as for the win7 index scores, only memory score went up from 7.8 to 7.9, while the other stayed the same. and heaven2.1 score went up from 372 to 383, FPS up from 14.8 to 15.2, min FPS up from 8.2 to 8.3, max FPS up from 32.6 to 35.9.
Not terribly significant differences there - assuming those aren't just within the margin of error, not sure it's worth the extra power and heat for those pretty small gains.
I had success overclocking 24 hours stable at 5ghz.
But my h70 corsair i felt wasnt cooling properly, even when not under load.. ie: in the bios it read 54-55C at 5ghz at 1.41 volts.. roughly 39-40C in the bios at 3.4ghz for perspective.. i didnt think this was good (my max load at 5ghz was about 82C after several hours of prime95, it would fluctuate between 78-82 etc, at ambient of 21 or 22C). Things were set as exhaust.
I used 90% alcohol to redo with arctic matrix mx4, several times, no change.. nothing i did mattered and the radiator when removing a fan didnt even feel warm..
So now my asus p8p67 deluxe board suddenly crapped on me..
I had a mem ok red led on trying to post (wouldnt post).. took out all but 1 chip, posted ok.. then it would shut off and the cpu red led came on..
I managed to get it to post again.. looked in bios it said 75C.. i tried shutting down and making sure everything was ok with the h70, it was, turned back on and i got a cpu overheat message on post.
Has anything like this ever happened to anyone thus far?
I'm basically going to try swapping parts to figure out what the problem is.. even if a cmos clear fixes the post, i still would feel better with a replacement board i think?
Something is amiss big time.. i had a perfect though a tad warm at prime95 max load, 5ghz setup and shouldnt have tried to mess with the paste i guess
Is it possibly your H70 pump isn't working? Can you it start pumping when turning on your PC?
Still not stable with Prime
I'm able to stablize with IBT without any issue at 4.8ghz at 1.415 and 1.425 both, but not stable with Prime BSOD in few min..
My System Specs
i7-2600k
Here are my settings
UEFI Bios Version =============== 1204
Target CPU Turbo-Mode Speed =============== 4800
Target Dram Speed =============== 1333
Ai Overclock Tuner =============== Manual
BCLK/PEG Frequency =============== 100
Turbo Ratio =============== By All Cores (Can Adjust in OS)
By All Cores (Can Adjust In OS) =============== 48
Internal PLL Overvoltage =============== Auto
Memory Frequency =============== DDR3-1333
EPU Power Saving Mode =============== Disabled
>OC Tuner ===============
>Dram Timing Control ===============
-Dram CAS# Latency =============== 9
-Dram RAS# To CAS# Delay =============== 9
-Dram RAS# Pre Time =============== 9
-Dram RAS# Act Time =============== 24
-Dram Command Mode =============== 2(This I have no idea nothing listed on my memory)http://www.patriotmem.com/products/detailp.jsp?prodline=5&catid=23&prodgroupid=71&id=765&type=1>
CPU Power Management ===============
(Digi + VRM) ===============
Load-line Calibration =============== Ultra-High
VRM Frequency =============== Manual
VRM Fixed Frequency Mode =============== 350
Phase Control =============== Extreme
Duty Control =============== Extreme
CPU Curren Capability =============== 100%
Cpu Voltage =============== Manual Mode
Cpu Manual Voltage =============== 1.335
DRAM Voltage =============== Auto / 1.55 / 1.65
VCCSA Voltage =============== .95
VCCIO Voltage =============== 1.05
CPU PLL Voltage =============== Auto
CPU Spread Spectrum =============== Auto
For me, i had vccsa voltage and vccio volts at auto and i hit stability for 24 hours with prime95 blend at 1.385 for 4.8ghz (and 1.41 at 5ghz).
Wow.. that's awesome.. what is your memory and their settings and also are there any differences in the settings ?
Ok guys, so I have a P8P67 board with a 2500k and I'm using a CM V8 cooler.
I hit 4.5ghz stable at 1.25volts, load temps (Prim95) 60 deg C
4.7ghz stable at 1.31volts, load temps (Prime95) 69 deg C
5.0ghz at 1.41volts, load temps (Prime95) 84 deg C after a few minutes and I turned off my machine and clocked down.
So, question is, what is the safe maximum temp to run this CPU at?
What cooler should I use to hit 5ghz with decent temps? Seems like a lot of people are using the H70, what kind of load temps are folks getting at 5ghz with this cooler?
Thanks for the help.
p.s. this is my first post in this forum
Set LLC to regular = 0% and Internal PLL = disable because they will add voltages. Think, base voltage is ~1.23V. Thus, with everything lowest and/or default & +offset 0.040, [email protected] idle and [email protected] load.Are you guys using offset or manual for cpu voltage? I'm not sure I'm understanding wtf offset is actually doing.
In order to offset from something it needs a baseline level of voltage ~ WTF is the baseline?
For instance, after resetting bios I get cpu vcore of something like 1.2. By this I would want ideally to +.200 in order to get it to around 1.4 right?
Doesn't seem to be doing that. My voltage then becomes 1.367 after the next reboot; and then after some benching I notice the vcore get up to 1.6v in CPU-Z.
I've tried with both LLC set to regular and ultra high; seems to be doing this in either case.
I know that Intel's rec. is around 1.5-1.52 max vcore so this offset mystery is a little scary. Luckily my temps have been fairly good, highest I've seen so far is 58c.'
Currently on 1204.
My System Specs
i7-2600k
sleep works fine on my P8P67-M Pro, does it work at stock clocks or lower overclocks?
Sleep works if you don't enable Internal PLL. And, what do you mean by lower overclocks?
