Official 3dmark06 scores here (please read first post before posting)
archer101
Here are my scores and before you laugh this was done with amd 4000+ single core processor oc at 3084 from 2400 with an ati 320 meg the cheap one xt1950xt. I payed 75 dollars for processor and 199 for video card from egg. DFI micro board 75 dollars.
I'm in the top 5 comparison with this setup in both. I've got screen shots but could not figure out how to upload them. Don't think I have permission.
3DMark06
overall score: 5474
cpu score: 1209
3DMark05
overall score: 12053
cpu score: 6457
Isaiah45
3DMarks06 score: 10155
SM 2.0 4436
SM 3.0 4425
CPU 2761
E6600 @ 3.2Ghz 36'C AIR
8800GTS @ 650/1950 58'C STOCK :)
Asus P5B Deluxe
Isaiah45
http://service.futuremark.com/orb/resultanalyzer.jsp?projectType=14&XLID=0&UID=8864474
SM 2.0 4436
SM 3.0 4425
CPU 2761
E6600 @ 3.2Ghz 36'C
Single 8800GTS @ 650/1950 58'C Stock Cooling :)
Asus P5B Deluxe
mentok1982
I went home for lunch and ran 3DMark06 on my new system. All my components are currently
at stock speeds.
http://service.futuremark.com/compare?3dm06=1775045
3DMark Score 10,996 3DMarks
SM 2.0 Score 4,555 Marks
SM 3.0 Score 4,621 Marks
CPU Score 3,564 Marks
After the 200 hundred burn in period is over I will be back with some overclocked results!
Here is the score from my old system:
3DMark Score 2,349 3DMarks
SM 2.0 Score 1,016 Marks
SM 3.0 Score 891 Marks
CPU Score 867 Marks
Athlon 64 3500+ Winchester, PNY 6800 GT, 1 GB OCZ, Windows XP Pro
QuiXylvR
12679 3DMarks
http://service.futuremark.com/compare?3dm06=1042541
________________________________________________________________
Main Test Results
3DMark Score 12679 3DMarks
SM 2.0 Score 4795 Marks
SM 3.0 Score 5473 Marks
CPU Score 4746 Marks
System Information
Operating System Microsoft Windows XP
DirectX Version 9.0c
Mobo Manufacturer ASUSTeK Computer INC.
Mobo Model P5W DH Deluxe - ATX - i975X
CPU Name Intel Core 2 Quad 3204 MHz (OC'd)
Physical / Logical CPUs 1 / 4
MultiCore 4 Processor Cores
FSB 320 MHz
Memory 2048 MB ( Operating System only recognises 2g due to 32-bit restraints )
ATI X1950XTX 512MCrossfire Edition + ATI X1950XTX 512M
Air Cooled.
Antec Truepower 2.0 550w
orion23
A little update
Q6600 3.9ghz 1.6125V in Bios. 1.58 In Windows
8800GTX 655 / 1910
13389
http://service.futuremark.com/orb/resultanalyzer.jsp?projectType=14&XLID=0&UID=10314392
BTK17
ASUS A8N5X nForce4 939 Mobo
AMD Athlon 64 4000+ GHz @ 3,068 MHz (E6 Revision, LCBBE) Freezer 64 PRO
1 GB RAM - G.SKILL ZX @ 2-3-3-5 DDR209 (204.5 MHz) 1T
XFX 7900GS @ 640/950 (1,900) MHz (163.44 BETA)
Western Digital 250GB 7200RPM 16MB Cache SATA HD
Corsair HX520W PSU
XP Home Edition
http://img299.imageshack.us/img299/7716/3d06ku3.jpg
Porter_
Does this seem about right? I've looked through this thread a little bit and from what I can tell it looks like my cpu score is a little high and my gpu score a little low.
edit: had driver issues, reposted on next page.
Porter_
Ran DC and installed 163.67 Beta drivers:
Q6600 @ stock clock speeds, 8800GTS @ stock clock speeds
silent-circuit
E6420 @ 3.5Ghz, 1.5 vcore (in BIOS, not after vdroop) for the benchmark. It's Orthos stable, I'm just too lazy to let it run long enough and it runs a little hot, like mid 60s C after a few minutes at full load. Cannot get it stable at 3.6Ghz, not sure if it's the RAM or my unwillingness to feed the proc. more than 1.55 vcore...
2GB OCZ DDR2-800 at 875Mhz, 5-5-5-14 T2. I can probably do better on the timings, just haven't messed with them.
8800 GTX at 675Mhz core, 1566Mhz Shader, 1024Mhz (2050Mhz DDR) RAM. 45C max temp under load. Higher on core or RAM and it starts to artifact with ATItool's scanner. Not sure why, really, as temps seem to be just fine. Running 163.67 betas.
Porter_
Q6600 @ 3.0Ghz (1.2625 vcore), 62ºC full load (Prime95)
8800GTS @ 650/975, 70ºC full load
KamelRed
Q6600 @ 3.24ghz (8x405mhz)
eVGA 8800GTS 320mb (stock 500/1600)
Nvidia Beta driver 163.67
Vista 32-bit
KamelRed
Just throwing up some scores after some farther overclocking. I think I probably hit the limit of my hardware and pushing any farther might break something. :D
3DMark Score:12466
S.M. 2.0 Score: 5106
S.M. 3.0 Score: 4910
CPU Score: 4870
Q6600 @ 3.4hz (8x425 4-4-4-12)
eVGA 8800GTS 320mb (675/1674/1008)
Nvidia 163.69 WHQL
JC316
E4300@ 3.4GHZ
HD2900 pro @ 800/900
GPU-Z Malfunctioned, it's at 800/900
BrakeSnake
I've just bought a new system and have been wondering about it's performance so I tried 3DMark06...
3DMark only lists One 8800GTS 640mb card, where as I am running Two. I've tried in SLI and non-SLI mode, and this does not change. The scores in SLI mode are better than non-enabled;
3D : 11581
SM2.0 : 4496
SM3.0 : 5396
CPU : 3408
Do these seem reasonable?
Also, 3DMark only shows 3077 mb of RAM, when I infact have 4GB DDR2 RAM (only 667)...???
Intel Core2 Quad Q6600 @2.40GHz
Nvidia GeForce 640mb 8800GTS X2
P6N SLI V2/ Ultra Motherboard
2 x SCSII 360mb Hard Drives
4 GB DDR2 RAM (667)
How do I enable the DUALCORE CENTER program to show the motherboard clocking/voltages. It Only shows the VGA settings, and the Start-up BIOS shows Dynamic OverClocking DISABLED (When I enable this it seems to crash a lot, but I can't find where to access Core Temps/Voltages/Frequencies...???):confused::confused:
Thanks Guys
Koko56
Your score is pretty good and windows 32-bit can only recognize up to ~3.5 GB of Ram in total, including the GPU RAM. If you wanna use all 4GB or more than then you'll want a 64-bit OS.
CryMod
Q6600 @ 3.6Ghz, EVGA 8800GTX, Driver 169.4, 656/1048 - and still not happy with Crysis performance!!
Nick[D]vB
My old 8800GTS 320 @ 650 / 1500 / 950 -ish :
My shiney new 8800GT @ 762 / 1863 / 979 :
My poor old Toledo can only get to 2.8GHz which is really holding it back, the SM2 score seems to be pegged to CPU clock.
Roll on PhenomX4.... :D
2k3eblade
3DMark Score 10496 3DMarks
SM 2.0 Score 4692 Marks
SM 3.0 Score 4630 Marks
CPU Score 2687 Marks
This is with ONE GTS (600/1400/2000). My other GTS was sent to evga step up for a GT.
