Computer Ed
- Nov 15, 2007
Okay folks with Office 2010 beginning to appear tp partners this means we will see it soon in the retail channel. There is an issue when using the 64 bit version of Outlook. Yes office can now be had in 64 bit.
The 64 bit version of Outlook will NOT sync with any Windows phones or with any mobile device that uses Windows Mobile Device Center for syncing.
Microsoft has stated in their partner forums that this issue is with WMDC and not Outlook however while they know of this problem there will NOT be a fix forth coming.
You hear right MS has admited they know the issue and said they will not fix it. They suggest that instead users only install the 32 bit version if they need to sync outlook using WMDC.
This is worse than sad...
Kyle this is a big enough deal I am wondering if it should not be a front page story. BTW I have the release of 2010 (MAPS) and have confirmed this issue.
