Office 2003 or 2007?
Discussion in 'General Software' started by K10, Oct 19, 2007.
  1. K10
    K10 2[H]4U
    3,316
    Mar 28, 2005
    i have both office 2003 and 2007 and i'm not sure if i should load 2007 onto my new system with vista 64. i'm concerned that 2007 has too many features that i don't need and i won't like its slightly different interface.
    any thoughts?
  2. SuperSubZero
    SuperSubZero 2[H]4U
    3,518
    Nov 21, 2000
    Control Panel -> Programs and Features -> Office version you installed and don't want -> Remove.
    It's not really that hard to play with both.
  3. FanZ
    FanZ [H]ard|Gawd
    1,969
    May 7, 2002
    he's asking which one he should put on his new system, not how to remove one..
    personally, i like 2003 better, just because i cant get used to the new interface on the 2007. nothing's worse when you're up at 5AM, have a paper due in a few hours, and have to spend half the time figuring out how to find options in 2k7. some will swear by the new interface though, i just dont like change.
  4. Oh4Sh0
    Oh4Sh0 2[H]4U
    2,746
    Mar 13, 2005
    republican :eek: lol.
  5. riot8ap
    riot8ap [H]ardness Supreme
    5,515
    Feb 17, 2003
    You may as well learn 2007 since it'll be around for awhile. The only downside is that if you save your files as 2007 you need to use a converter pack if you want to view them on a 2003 computer. (or just save them as an older version)
  6. Tytalus
    Tytalus [H]ardness Supreme
    4,336
    Nov 1, 2006
    I use 2007 at work and the interface isn't "slightly different". It's a wholly redesigned theme with the ribbon and other features.
    I do ok with it, but I have to mangle it a lot to get it where I want it to be. It involved extensive configuration changes but it's to the point where I'm happy with it.
    [​IMG]
  7. RangerSVT
    RangerSVT [H]ard|Gawd
    1,997
    Jun 7, 2007
    I have Office 2007 and I hate it, but have to live with it. I prefer the old Office XP style, I guess there are changes for a reason though ;)
  8. rgratto2
    rgratto2 2[H]4U
    2,326
    Jul 22, 2005
    Once you get used to the UI of 2007, its really a lot more intuitive.
  9. K10
    K10 2[H]4U
    3,316
    Mar 28, 2005
    is anyone running office 2003 on vista 64? are there any issues with it?
  10. TheGamerZ
    TheGamerZ [H]ardness Supreme
    5,218
    Sep 18, 2003
    I actually prefer the new UI for 2007. The old interface was becoming too convoluted and options were just being thrown into menus wherever they could be fit. The Ribbon interface is quite intuitive and organized all the most commonly used functions in a very straight-forward and logical fashion.
    my 2ยข
  11. Zero82z
    Zero82z Stay [H]ard
    28,011
    Jan 20, 2004
    It takes some getting used to, but the new interface is really a lot faster and more intuitive than the traditional layout. I much prefer it to the old version.
  12. iRoNeTiK
    iRoNeTiK Vodka Martinis are for the Weak
    1,420
    Aug 4, 2003
    It didn't take long for me to "learn" 2007. The interface is cleaner and more organized with the use of tabs, that categorize functions under the appropriate tab, so it's easy to find and you get all (well most) under each tab, while 2003 you had to use pull down menus or go into an options dialog box to find more "advanced "features."
    Since 2007 introduced a new file format, i always save my documents in the Word 97-2003 format, since not everyone is on Office 2007 and haven't experienced any problems. I would go with Office 2007 :)
  13. The-One
    The-One Gawd
    882
    Sep 17, 2006
    Get Office 2008 beta;)
  14. UnknownSeeker
    UnknownSeeker Limp Gawd
    198
    Jul 21, 2006
    IMO: You mine as well install 07 and get use to it. Whether or not you want to learn a new GUI it is here and will probably stay. Plus now you will be able to open 07 files, though you will probably end up saving a lot of 03 files if you need to send it to someone.
  15. iRoNeTiK
    1,420
    Aug 4, 2003
    I think office 2008 beta is for Mac
  16. The-One
    The-One Gawd
    882
    Sep 17, 2006
    I think it is to but I was kidding, sorry
  17. Zero82z
    Zero82z Stay [H]ard
    28,011
    Jan 20, 2004
    By the way, you can also set Office 2007 to save files as legacy .doc files instead of .docx if you need to use your documents on older computers. I have it set that way and it makes things a lot easier since I don't have to manually change the file format every time I save a document.
  18. ne1wantaride
    ne1wantaride [H]ard|Gawd
    1,423
    Feb 8, 2003
    For work I save everything in Office 2007. It forces people to get the new version or download the compatibility pack. It's their problem not mine. ;)
  19. Koslov
    Koslov [H]ard|Gawd
    1,889
    Aug 31, 2003
    Office 2007. It is a lot more polished in my opinion. The learning curve from 2003 is about 2-3 hours max. Really nice
  20. darktiger
    darktiger [H]ard|DCer of the Month - April 2007
    11,831
    Apr 10, 2003
    I second this. I like Office 2007 hands down. Only took like 15 minutes to get use to the new UI. Even changed it black.....
  21. Oline61
    Oline61 Gawd
    869
    Aug 8, 2005
    2007.
    Getting used to the new UI isn't difficult, and I've found it to be much more intuitive than the old one.
  22. ChingChang
    ChingChang [H]ardness Supreme
    6,523
    Mar 27, 2003
    Office 2007 is betterer.
  23. Zardoz
    Zardoz 2[H]4U
    3,257
    Aug 27, 2000
    I really like office 2007, but some people like the old menu styles
  24. K10
    K10 2[H]4U
    3,316
    Mar 28, 2005
    is there anyway to make 2007 look like 2003?
  25. Zero82z
    Zero82z Stay [H]ard
    28,011
    Jan 20, 2004
    Nope, not as far as I know. I believe Microsoft purposely didn't include a legacy UI because they want people to get familiar with the new interface.
  26. Domingow
    Domingow 2[H]4U
    3,098
    Jan 3, 2001
    I believe that this just might be what you are looking for.
    Essnetially this brings back the 2003 office toolbar.
  27. Dario D.
    Dario D. Gawd
    582
    Dec 8, 2004
    The interface in Office 2007 (or at least Word 2007) is extremely visual, easy, open, accessible, and helpful (every feature has hover tool-tips). Absolutely great in my opinion.
  28. K10
    K10 2[H]4U
    3,316
    Mar 28, 2005
    thanks shyboi. unfortunately, my work place is stuck on 2003 and it's hard using the 2007 UI at home and then 2003 at home. anyone else agree?
  29. anthrex
    anthrex [H]ard|Gawd
    1,874
    Jul 7, 2004
    2007 is fantastic, but it definitely is difficult to switch back and forth between 03 and 07 because the interface just seems so much clunkier and slower to use when I was back home during the summer.
  30. DeaconFrost
    DeaconFrost [H]ardForum Junkie
    10,927
    Sep 6, 2007
    This is definitely true, even for non-technical folks. My company is made up mostly of people who fear technology, but they are doing very well with Office 2007. We use the Save to PDF add-on quite a bit.
  31. K10
    K10 2[H]4U
    3,316
    Mar 28, 2005
    how did you change the UI to black?
  32. xaneshx
    xaneshx n00bie
    44
    Jan 28, 2007
    All you have to do, to change the ui from blue to black is the following: click on the office orb on the top left of the window, then on the bottom of that box there should be something that says Word Options, and in the Popular Tab, right in the middle of the square you should see Color Scheme with a drop down triangle list. Just select which one you want and there you have it. You can chose from blue, silver and black.
  33. K10
    K10 2[H]4U
    3,316
    Mar 28, 2005
    thanks guy. i wish my work would switch to 2007 so i don't have to use both 2003 and 2007.
  34. zmjone2992
    zmjone2992 [H]ard|Gawd
    1,034
    Jul 3, 2007
    i love 2007, no turning back
  35. Koslov
    Koslov [H]ard|Gawd
    1,889
    Aug 31, 2003
    You can always use a 'portable office 2007' on a USB stick at work.
    google up Thinstall or PM me if you need help or direction.
    This is what I would do.
  36. Azhar
    Azhar Fixing stupid since 1972
    18,907
    Jan 9, 2001
    To those who haven't tried Office 2007 and wants to know if they'll like it before buying it, I suggest you go here and try the trial (virtualize it if you're afraid to mess anything up).
    http://www.microsoft.com/downloads/...BF-D86A-4ACF-9DCC-4D61F500AD6D&displaylang=en
    Suggest this link to your work's IT admins and managers so they can try out Office 2007 in their current infrastructure so they can determine if it'll improve or break anything.
