Guys,
I work as a Sr. Systems Admin with Linux, Solaris, and AIX everyday. The time has come for me to upgrade my home network to gigabit as I'm backing up a lot of data to an IBM Ultrium LTO-3 tape drive.
Long story short, my two primary systems are based on Nforce4 boards with Gigabit ethernet. One system is an SN25P and the other uses an Asus A8n32-SLI motherboard. Both are on a 192.168.200.0 network using a mask of 255.255.255.0. My router is a Linksys WRT54G with an IP of 192.168.200.254/24.
System 1: 192.168.200.1
System 2: 192.168.200.183
System 3: 192.168.200.253
Router: 192.168.200.254
System 1,2,3 are on Gigabit. System3 is my Linux server running Suse 9.1 with an Intel Pro/1000 NIC. All three of these systems are connected via Cat6 cable to an SMC 10/100/1000 5 port switch which is uplinked to my Linksys router.
Problem: System 1 is my SN25P running WinXP PRO SP2. It can ping System2 and my router, but it cannot ping System 3. System 2 can ping all systems. System 3 cannot ping or connect to System 1, but can connect to everything else.
So for some reason I cannot get System 1 and System 3 to talk to each other over Gigabit. I'm at a loss here because all of the masks, MTU's, etc all match. I'm not using Jumbo frames yet. Each system does have connectivity to the internet. I tried rebooting, clearing the arp tables, etc - no dice. Running TPCDUMP on my Linux server does not show any traffic from 192.168.200.1.
Any thoughts?
Any thoughts?
