I have a shared folder on PC1.
PC1 has a camera with pictures and videos that export into said shared folder.
PC2 has read/write access to the shared folder.
On PC1 I export pictures into the shared folder, i go to PC2 they aren't there. After a while they show up, I haven't figured out a time frame on how long they take to show up. I've hit F5 to refresh the folder, I've closed windows explorer and rebrowsed to the folder, I've tried mapping the folder - no success.
I've tried googling but I either don't know the right string or it isn't a common enough problem.
edit, add: It is not the exporting process either, even if I create a text document.txt in the folder on PC1 and go check on PC2 it won't be there for some random amount of time. I can view and edit the contents of the folder and still not have the most updated list of files, I have not checked via command prompt yet, I'll try it tomorrow.
edit2 add: I pinged the machine while the file list was out of date, the pings went through fine.
I first noticed the problem a couple weeks ago.
Anyone have any ideas?
