First thing first, here is the system spec:
P4 3.0E (SL79L) - WC
Gigabyte GA 8i875 Ultra
OCZ EL DDR PC-3200 Dual Channel Platinum Rev 2 (2x512MB, TCCD)
600W Power supply
The thing is, as soon as I use CAS 2.5-x-x-x instead of CAS 2.0-x-x-x, I'm getting errors in memtest and it is from DDR400 to DDR480 (didn't try higher). Anyone have an idea why it happen?? Before, with my Corsair TwinX1024-3200C2 v3.1 (Infineon B5), there was no problem running it at 2.5-x-x-x. I'm a bit clueless about this!
600W Power supply
