For some odd reason, the OCZ DDR400 Platinum EL 2x1GB dual channel kit I purchased on boxing day, does NOT run at 2-3-2-5 like advertised. SPD reports as 2.5-3-2-5. I cannot run 2-3-2-5 at 1T, however 2T works fine. But the funny thing is, SPD is CAS 2.5, shouldn't it be 2?
The memory is this:
http://www.ncix.com/products/index.php?sku=14504&vpn=OCZ4002048ELDCPE-K&manufacture=OCZ Technology
I am running this with:
AMD Athlon X2 3800+ Manchester
Asus A8N-SLi Deluxe w/ 1015 BIOS
OCZ DDR400 PC3200 Platinum EL 2x1GB Dual Channel currently running at 2.5-3-2-5 at 1T
eVGA 7800GT CO
Maxtor DiamondMax Plus 10 250GB 7200RPM 16MB Cache
Antec TruePower2.0 TPII-550W SLi Certified
Why can't I run 2-3-2-5 at 1T? If I try it, my computer won't run Super PI, fails Prime95 after a few seconds, etc.
The memory is this:
eVGA 7800GT CO
