Hi All
I've got the ASUS M3A78-EMH mATX AM2+ board with a Brisbane 5000+
Back with socket 754, I decided to try my hand at AMD64 hardware to go
with the 2 P4 machines I already had in my home office/shop/lounge area.
The P4s beat the the 754 setup hands down, so I stayed with Intel then.
After playing with my ABIT AW9D-MAX + Pentium D940 machine a year,
I decided to give AMD's new AM2 socket and Spider platform a go.
I realize that I need to deal with the HTT system as well as the Bus Speed
when overclocking my 5000+ (not BE), but I got a little disappointed when
the highest Bus Speed I could get to load under Windows was about 245MHz
Of course, as a mainstream motherboard, the M3A78-EMH is a BiiiiiiiT scanty
on the OCing features, I can set minimum VID for the CPU, the RAM clock as
200/266/333/400(/533 for Phenoms), RAM timings, RAM voltage up to 2.2v,
and the Bus Speed from 200 to 300 in 1MHz increments (this is actually a big
win over the MSI 690G I tried first BLEH! none at all, natch ...
So what am I missing besides a better board for OCing? I set the HTT multiplier
to 4X (800MHz) to keep the HTT around 1000MHz with the upped Bus Speed,
but no matter what I try, 245 won't even boot, goes back to default, and a BIOS
message pops up "Over Clock Failed Press F1 To Continue F2 To Reset Defaults"
I appreciate any insight or instruction you can provide me here.
I am using a Scythe Mine HSF, so the CPU temps are no problem...
