sitheris
- Jul 30, 2004
I am trying to do my first OC on my Q9450. Cooling it with a Xigmatek S1283.
I have it running stable for 30 min in Prime95 at 3.2ghz (400x8), with a 1:1 memory divider. My vcore is set to auto in my bios and I see it at around 1.36v in CPU-Z (1.25 is stock I believe?)
My temps after running P95 for 30 min on all four cores reached an average (across cores) of 62 C max, with Core 1 being the highest at 66 C at one point.
My Idle temps are averaging 36-37 C.
I just wanted to compare with others having similar setups, to see if my temps are good. Should I try taking vcore off of auto and decreasing it a bit? So far this OC seems stable to me.
Full system specs are in sig.
Thanks for looking
Thanks for looking
