NZXT Phantom 630 with Corsair H115i Push/Pull?
Kanuki
Hi.. Guys...
Does anyone here know whether NZXT Phantom 630 can fit
top mount Corsair H115i with Push/Pull configuration?
Look up your case on PartPicker. Then look at the compatible CPU coolers - NZXT Phantom 630 Windowed Edition (White) ATX Full Tower Case Compatible CPU Coolers - PCPartPicker Australia. The H115i is listed.
The Phantom 630 website - Phantom 630 Windowed Edition White - PC Computer Gaming Case - NZXT shows a radiator attached to the top. But the fans then can only go on top of the case as there won't be enough room under the radiator. So you can only use push OR pull. Not both.
Thank you so much... I've ended up buy Cryorig A80 because managed to get some good deal. But I still don't have chance to install it yet.
