NZXT H440 Rigid Tubing Build
Discussion in 'Worklogs' started by Makeroflostsouls, Jan 2, 2017.
  1. Makeroflostsouls
    Makeroflostsouls 2[H]4U
    2,308
    Jun 4, 2008
    Starting a new build.
    Case NZXT H440
    CPU 5820k
    MB MSI Godlike Carbon x99
    RAM 16gigs of Corsair LED DD4 3200
    Video cards Dual 1070 GTX FTW EVGA
    Cooling dual 360mm rads ( have a RX360 and AX360 but not going to fit)
    XSPC D5 Photon 170
    Fans Corsair ML120's x 7
    Really like this case. Be my second build with it. Here is my first build with it. This will be my first water cooled build witht the case. So wish me luck on it lol. Not my first water cooling build though. Done several, one with a water chiller :)..
    [​IMG]
    Started on the case today. Took out the drive bays to be able to fit a radiator in the front.
    [​IMG]
    [​IMG]
    Got that done started some test fitting.
    [​IMG]
    So the AX360 rad is not working to work in the top (now for sale). Going to have to get a different radiator for the top. Didn't think about the squareness of the AX not fitting in the top properly. Have to go with a thinner radiator in the top. RX fits fine, might have to lose the end fan in the top but shouldn't be a issue. More then enough cooling for a i7 7700k and dual 1070's. Going to make a braket for the XSPC Photon to mount to off of the motherboard tray.
  2. Makeroflostsouls
    2,308
    Jun 4, 2008
