nvidia temp monitor other than gpu z
GonzoP
Tried the search function and didn't find an answer.
I know the old forceware drivers and what not had the temp monitoring.
I DL'd GPU-Z and that's a cute little app.
Is there any other way to monitor temps from within say the nvidia control panel itself? I installed the system tools so I can change the clocks and fan speed but didn't see anything for temps.
+1 for evga precision tool.
yeah i really liked this tool when i had my 8800GT. in fact i uninstalled riva tuner with all my custom fan profiles and just used EVGA's precision tool. good stuff.
Rivatuner has a very good graphing tool.
I'm currently displaying:
Clock speeds for Core Shader and Memory
GPU Core Temp
Frames Per Second (while gaming)
Ambient temp
CPU usage for each core
Physical memory
Video memory
Local Video memory
Evga precision tool is very simple and effective. Rivatuner is simply the best tool out there but some might find it a bit complex to use. MSI Dual Core Center works great and has been a while for quite some time...but unfortunately it only works with msi hardware.
I assume any nvidia card will due even those not from evga?
Correct, i believe this will work with any Nvidia based card starting from the 6 series and up.:)
But you do have to sign up for the EVGA forums and be a member to be able to download it. ;)
