Nvidia Surround support for 5050x1600?
stevedave
are there any update from NVIDIA coming out anytime soon that will allow my 20" - 30" - 20" setup to work?
you'd think 1200x1600 - 2650x1600 - 1200x1600 wouldn't be that hard to get working.
Can eyefinity do this?
As far as I know none. With eyefinity 2.0 just released you likely will not see something like this until the next gen at least for AMD. Maybe Nvidia might have a surprise with the GK110? Although Nvidia seems to have less focus on this front than AMD.
While this isn't possible with Surround/Eyefinity you can do this using a "hacked" together solution. For example running the game in windowed mode spanned across the displays.
Interesting I'll try that out just too see what it looks like. This solidified sticking with my 460gtx sli setup and skipping a few generations of cards.
Thank you
