Christopher
- Sep 16, 2002
Not sure if this question should go in mobile computing or Nvidia graphics cards, but since optimus is primarily a mobile thing, lets try here.
Is there a way to make a particular shortcut use the Nvidia GPU by default?
Background: I've got a laptop with Windows 7 x64, a Nvidia NVS 3100M with optimus. Running minecraft, which is a java application, by default will render on the integrated Intel GPU. The performance is obviously poor. If I right-click on the shortcut and choose "Run with NVIDIA processer" it works great. I can, in Nvidia control panel, set all java applications to run using the Nvidia GPU, but I don't want that, only the minecraft shortcut should. I have other java applications that I run where using the nvidia gpu would just waste battery life.
So my question is, can I make a particular shortcut use the nvidia GPU, without matching everything that is ran by java? It seems like there should a command line tool that I could wrap it in to use the faster GPU for this application, but my google searches for such a thing have turned up empty.
