Nvidia Nforce 570 ethernet teaming question
Myrandex
I have an nforce 570 sli system and I have enabled teaming, and I was wondering if I should see one or two ethernet cards listed on the system. Also, my system is extremely slow to start ethernet. Windows will be completely finished bootin and about 2 minutes later, my ethernet icon starts up. Currently the system is clean as here is how I set it up:
Install Windows XP SP1 a, installed SP2 immediately following completion of setup
Install newest motherboard drivers, reboot.
Install newest VGA drivers, reboot.
Install AMD CPU driver, reboot.
Install all windows updates, involves 3 reboots.
Installed Nero 6 OEM, updated, installed Free AVG, updated, reboot.
Here is the config:
AMD AthlonX2 5400+ 2.8GHz.
Abit KN9 SLI (bios has audio disabled, both ethernet enabled, floppy controller disabled)
Seagate 500GB SATA2 16MB Cache
2 x MSI 7100GS 128MB (not running SLI, used for multi monitor)
Samsung 18X DVD+-R(W) SATA burner
600W SLI certified Power Supply
Thanks Guys!
Jason
edit -> Noticed in event viewer that "Forceware IP service hung on startup" existed on every reboot. Also in my environment I am pretty sure that I will see a difference, as these boxes have the chance of many PCs pulling ~4GB images off at the same time (hence I am trying to team the connections together on a 2gb switch).
