NVIDIA Launches GeForce GTX 1060 with 6GB GDDR5X Memory
Discussion in 'HardForum Tech News' started by Megalith, Oct 20, 2018.
  1. Megalith
    Megalith 24-bit/48kHz Staff Member
    13,004
    Aug 20, 2006
    NVIDIA’s official GeForce GTX 1060 landing page now alludes to a new model of the Pascal-era GPU: the specs section has been updated with a “GeForce GTX 1060 6 GB” featuring 6 GB of GDDR5/X memory. Hot Hardware suggests this is NVIDIA’s way of countering AMD’s upcoming Polaris refresh.
    NVIDIA's specifications chart doesn't differentiate memory speeds between the GDDR5 and GDDR5X versions, and simply lists 8Gbps. However, that doesn't necessarily mean the GDDR5X variant will not be clocked a little faster, as NVIDIA doesn't differentiate between 8Gbps and 9Gbps GDDR5 variants either. It's all a little confusing at the moment.
  2. NWRMidnight
    NWRMidnight Limp Gawd
    187
    Oct 23, 2010
  3. ole-m
    ole-m Limp Gawd
    406
    Oct 5, 2015
  4. Brent_Justice
    Brent_Justice [H] Video Card Managing Editor Staff Member
    17,757
    Apr 17, 2000
    The difference though is that this is GDDR5"X" memory, which as we know can operate 10GHz/11GHz and even 12GHz with good power and cooling.
    Even just 9GHz would raise the memory bandwidth from 192GB/sec to 216GB/sec and 10GHz would make it 240GB/sec and 11GHz would be 264GB/sec etc....
    No telling what it will end up being yet I guess or the potential in overclock.
    Interesting that NV is going for mem bandwidth upgrade, and AMD is going for engine clock speed.
  5. prime2515102
    prime2515102 [H]ard|Gawd
    1,503
    Mar 3, 2003
    Should I sell my 1080 and get one of these? :wacky:
    Shadowed and Viper16 like this.
  6. spintroniX
    spintroniX Gawd
    958
    Apr 7, 2009
    Not sure it's so useful for gamers, but it looks like a good little GPU to get into deep learning.
  7. viper1152012
    viper1152012 [H]ard|Gawd
    1,025
    Jun 20, 2012
    My wife's 1060 msi armor is good enough for everything at 1080p..
    Would this Just be a step between 1060 and 1070.
  8. Stoly
    Stoly [H]ardness Supreme
    6,094
    Jul 26, 2005
    I'm guessing OEMs will release OC cards which should benefit from the extra bandwidth and get better performance.
    BTW Pascal doesn't have tensor cores, so no deep learning.
    Dayaks likes this.
  9. Ehren8879
    Ehren8879 [H]ardness Supreme
    4,257
    Sep 24, 2004
    i find it interesting that NVIDIA doesn't consider the 2060 a competitor to a Polaris refresh.
    This is a weird time to be alive in GPU land
  10. spintroniX
    spintroniX Gawd
    958
    Apr 7, 2009
    You don't need tensor cores for deep learning. They accelerate certain types of calculations, but aren't required to do them.
  11. Nightfire
    Nightfire [H]ard|Gawd
    1,398
    Sep 7, 2017
    This should have specs that are VERY similar to the 980ti, right?
  12. zkostik
    zkostik Gawd
    931
    Sep 17, 2009
    I'm not surprised given the new pricing scheme of RTX cards. RTX2060 will likely be too expensive for the market gap it's supposed to fill unless they create a huge price gap between 2060 and 2070. For most gamers 1060 is probably decent enough as it runs everything maxed out at 1080p and can do VR as well as reasonable settings.
  13. SickBeast
    SickBeast Limp Gawd
    498
    Jan 29, 2012
    AMD is also releasing a Radeon RX 590 card. It looks like a die shrunk Xbox Scorpio GPU to me. This screams of industrial espionage. How did nVidia know that AMD was poised to release a new GPU? This all seems way to coincidental to me. There has to be a mole.
  14. tikiman2012
    tikiman2012 [H]ard|Gawd
    1,228
    Dec 16, 2009
    More overpriced nvidia junk.
  15. ccityinstaller
    ccityinstaller 2[H]4U
    3,814
    Feb 23, 2007
    Not even close..The 980TI, especially AIB models with good cooling, are on a par or faster then a 1070. Think of this as a 1065...
  16. Rob94hawk
    Rob94hawk 2[H]4U
    2,067
    Jul 20, 2002
    Still have my 780. I think I'll wait a few years more.
  17. funkydmunky
    funkydmunky 2[H]4U
    2,236
    Aug 28, 2008
    I don't like this 1060 trend of different models. Just leads to consumer confusion.
  18. SickBeast
    SickBeast Limp Gawd
    498
    Jan 29, 2012
    At least they are actually enhancing the card this time. We have seen way too many instances of bait and switch lately. The RX 580 is the latest example. Fine, the cards are meant for Asia only but that means that now it's impossible to know which GPU you are getting if you are buying a card off of Ebay. nVidia did this with one of their cards also recently. I believe they put DDR4 RAM on the card which gave it 1/3 the performance.
    Shadowed and Nightfire like this.
  19. Dayaks
    Dayaks [H]ardness Supreme
    6,657
    Feb 22, 2012
    2060 and under will not have RTX features.
  20. Master_shake_
    Master_shake_ [H]ardness Supreme
    8,190
    Apr 9, 2012
  21. funkydmunky
    funkydmunky 2[H]4U
    2,236
    Aug 28, 2008
    It is still intended to confuse. Throw a "ti" on it. Both camps need to clean things up. Whats wrong with a card ending in a 5? They used to all the time.
  22. 92miata
    92miata Limp Gawd
    428
    Nov 13, 2006
    Because of Nvidia I have pretty much dropped PC gaming and moved to Consoles because of their GPU Pricing and tactics. Thank you Nvidia.
  23. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    8,731
    Jun 13, 2003
    :ROFLMAO:
  24. MV75
    MV75 [H]ard|Gawd
    1,025
    Nov 13, 2007
    ? I already have a 1060 with 6gb of ddr5 memory I bought like last year or whenever it was and it's half the size of that card. So this one has more memory bandwidth. Big fucking whoop. A faster gpu core along with more rather than just faster memory is always better.
  25. HeadRusch
    HeadRusch [H]ard|Gawd
    1,103
    Jun 8, 2007
    Memory Bandwidth = "I raised this up 600Mhz and I'm getting 3 extra FPS! WOOOOOOOOOOOOOOOOOOOOOOOOOOO!"
    ..for games, nobody beat me with the Compute stick please.......
  26. ole-m
    ole-m Limp Gawd
    406
    Oct 5, 2015
    It's confusing but it's just like the 1080 which was upgraded to gddr5x, they stop making the old one atleast so it's only a brief period and it usually comes at no extra cost for consumers... historically speaking.
  27. Burticus
    Burticus 2[H]4U
    3,785
    Nov 7, 2005
    And here it is... the 2060... the video card no one wanted.
  28. zkostik
    zkostik Gawd
    931
    Sep 17, 2009
    I don't think it really matters to most, though it would be interesting if that's the case. Either way, I'm more interested where it will be positioned in terms of price. Given this upgrade to 1060, 2060 must be way above the usual price point previous generation occupied. If it has no RTX it will likely not end well for it either as that's one of the main features NV is peddling with this generation which supposedly demands hefty increase in price.
  29. debaucher
    debaucher [H]ard|Gawd
    1,637
    Jan 13, 2002
    Not really new, just newly available to retail markets in the west (ie... outside of China). These have been around for at least a year as an OEM China only purchase mainly used for internet cafes. You could find them on the usual grey market websites but the cost was just NOT worth it. Some people still bought them during the bitcoin mining frenzy when they were the only thing remotely available.
  30. lostin3d
    lostin3d [H]ard|Gawd
    1,909
    Oct 13, 2016
    I admit I never heard that before. On the other hand it continues with the scrap yard approach I've commented many times on with NV and pascal. Really seems like they'll slap any spare parts together at this point to get rid of various stock. It'd be pretty amusing if someone did a family tree of just the desktop cards for Pascal. It's getting to be a pretty big tree.
