Oscar Meyer
- Oct 9, 2009
I mostly game on my asus 24 inch monitor, but I decided to hook up my tv located in another room via hdmi. Its a cheapo walmart 32 inch vizio. First thing I notice are the colors seem slightly washed out. Games like Dead Space 3, the darkness and what should be black is slightly gray. I researched the issue on the web and it seems Nvidia drivers have had this problem for a long time. It sometimes outputs limited RGB via hdmi. You can fix it by using a hack or using a custom resolution which makes it send Full RGB thru hdmi.
So I did the fix and now the images on my tv look good. Blacks are black. But now, my asus monitor looks a little less bright. The contrast between light and dark is not as pronounced any more. For instance, in Skyrim, the colors and brightness at 11:00am looks like its 4:00pm. There is alot less contrast between light and dark. The only way to fix this is to completely uninstall and reinstall the driver. The tool I used to make the video card send full RGB signal is this http://forums.guru3d.com/showthread.php?t=371214 . It works great in fixing the tv color, but it makes the signal to my asus monitor look dull. Anyone have any ideas?
