- Dec 19, 2005
From hardware unboxing, they equate it to a “4090 Ti” equivalent performance uplift and not necessarily a generational improvement… @ 4K
TPU Commenter quote : “35% more performance with 25% higher power draw”
“Performance
We upgraded our test system last month, which is now built on AMD technology with the outstanding Ryzen 7 9800X3D. We've updated to Windows 11 24H2, complete with the newest patches and updates, and have added a selection of new games. At 4K resolution, with pure rasterization, without ray tracing or DLSS, we measured a 35% performance uplift over the RTX 4090. While this is certainly impressive, it is considerably less than what we got from RTX 3090 Ti to RTX 4090 (+51%). NVIDIA still achieves their "twice the performance every second generation" rule: the RTX 5090 is twice as fast as the RTX 3090 Ti. There really isn't much on the market that RTX 5090 can be compared to. It's 75% faster than AMD's flagship the RX 7900 XTX. AMD has confirmed that they are not going for high-end with RDNA 4, and it's expected that the RX 9070 Series will end up somewhere between RX 7900 XT and RX 7900 GRE. This means that RTX 5090 is at least twice as fast as AMD's fastest next-generation card. Compared to the second-fastest Ada card, the RTX 4080 Super, the performance increase is 72%--wow!
There really is no question, RTX 5090 is the card you want for 4K gaming at maximum settings with all RT eye candy enabled. I guess you run the card at 1440p at insanely high FPS, but considering that DLSS 4 will give you those FPS even at 4K, the only reason why you would want to do that is if you really want the highest latency with the lowest FPS.”
Source: https://www.techpowerup.com/review/nvidia-geforce-rtx-5090-founders-edition/46.html
“Performance
